Neutral for A4 Question.
Old Jan 6, 2008 | 09:46 PM
Dominic Toretto's Avatar
Dominic Toretto
Default Neutral for A4 Question.
I don't think it's a problem, but I am not as technically inclined as some of you are. Is there any problem with coasting in the neutral gear when coming to a stop? Or what about while at a stop having the car in neutral? Just curious.
-Alex
Old Jan 6, 2008 | 10:57 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
-Alex
Why would you even want to do that? It makes no sense. Tell me your thinking on this subject
Old Jan 6, 2008 | 11:10 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
I used to do it a lot in my old Q45, to help improve gas mileage.
I don't think it hurt anything, but I have heard that the fluid pressure is reduced, and the clutches can wear more than usual.
I am not sure about that, but I do know that it really didn't make any difference with the mileage, so I don't do it in my current Q45, or any of my Corvettes.
Old Jan 6, 2008 | 11:13 PM
WetteVette's Avatar
WetteVette
Whether it actually "hurts" anything or not, I don't know.
However, that extra second it takes you to put the car back in gear in case of emergency might save your life.
Old Jan 6, 2008 | 11:17 PM
Don't know that it hurts anything, but I too don't see any use in doing it.
Old Jan 6, 2008 | 11:34 PM
GS Ron's Avatar
GS Ron
I would think that coasting in neutral and not using the trans to slow down would put more wear on the brakes Seen people use neutral downhill in the mountains to save gas and wind up riding the hell out of the brakes
Old Jan 7, 2008 | 07:43 PM
Dominic Toretto
I'm not talking about during autoXing or anything just normal stop and go traffic between lights from a calm 20-0mph.
Old Jan 7, 2008 | 08:15 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Need to get out of the way
Old Jan 7, 2008 | 08:31 PM
Wayne's World's Avatar
Wayne's World
Why would you want to? I don't see any advantage to doing so.
More wear on the brakes would be a result and unnecessary constant shifting from drive to neutral then neutral to drive couldn't be good for the tranny.
Old Jan 8, 2008 | 12:14 AM
jrose7004's Avatar
jrose7004
I can't imagine why you'd want to!
Old Jan 8, 2008 | 12:25 AM
Storm Cloud's Avatar
Storm Cloud
I do it on the on-ramp to the freeway when there is a light on at the bottom to enter the freeway.
I have to wait for each car ahead of me to stop then go. So....I put it in neutral and coast down and in the mean time rev my engine for fun to show off! to the shenanagans around me.
Once I reach the bottom of the on-ramp and make it to the light, then I put it into gear, wait for the green and I am gone!
Old Jan 8, 2008 | 01:48 AM
DeeGee's Avatar
DeeGee
The purists will say that coasting is a bad driving practice because the car is not fully under comtrol when its not in gear.
I'd say the box was designed to idle in drive. Can't see it can harm anything other than the increased wear of all the additional shifting on the shifter mechanism.
Old Jan 8, 2008 | 01:59 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
I think it hurts the trans. You can pick up some MPG.
Paul G.
Old Jan 8, 2008 | 07:27 AM
vetter79's Avatar
vetter79
I've never had any tranny probs doing it. and where I live, even with any vehicle, if you get caught on slippery roads (like in a quick snow shower), putting it into neutral to help with braking might just save your as-!
Old Jan 8, 2008 | 08:55 AM
Old Man in a C's Avatar
Old Man in a C
I'd think just the opposite. Motor drag on the rear wheels will tend keep you in a straight line until you need the brakes. My .02
Old Jan 8, 2008 | 02:44 PM
Dominic Toretto
How is it putting more wear on the brakes if I am not using the brakes at a stop?
Old Jan 9, 2008 | 04:03 AM
PierEagle's Avatar
PierEagle
If you shift into neutral while you are rolling up to a stop, all your stopping power comes from the brakes, ergo, increased brake wear. By leaving it in gear, foot off the gas until you stop, the motor helps to slow/stop you resulting in less brake wear over time. After you are stopped, shifting into neutral shouldn't hurt anything unless a.) you hit the gas when the light turns green while still in neutral and the guy behind you plays bumper tag, or b.) you accidently shift to reverse and hit the gas. (I've seen that happen a few times).
If neutral shift done routinely, I imagine over time there would be excess wear on your shifter and linkage, etc., then again, maybe not.
Cheers
To Neutral for A4 Question.
Old Jan 9, 2008 | 04:12 AM
Junkman2008's Avatar
Junkman2008
Originally Posted by PierEagle
If you shift into neutral while you are rolling up to a stop, all your stopping power comes from the brakes, ergo increased brake wear. Leaving it in gear, foot off the gas until you stop, and the motor helps to slow you resulting in less brake wear over time. After you are stopped, shifting into neutral shouldn't hurt anything unless a.) you hit the gas when the light turns green while still in neutral and the guy behind you plays bumper tag, or b.) you accidently shift to reverse and hit the gas. (I've seen that happen a few times).
Cheers
The OP has never said why he does this. What is the reasoning?
Old Jan 9, 2008 | 10:32 AM
Dominic Toretto
Cheers
Very well presented information. Thank you for that .
If your referring to me, I just brought it up because I was riding with a coworker to lunch and he does this in his car. Didn't seem like an issue for him, but as stated earlier, I am not technically inclined like most here which I is why I started the thread. But my eyes are opened now
-Alex
Old Jan 9, 2008 | 10:35 AM
Junkman2008
-Alex
Oh, okay!
