rotor question
Old Jan 7, 2008 | 04:06 PM
cosvette's Avatar
cosvette
Default rotor question
I recently became the proud owner of a '99 Coupe. During some shakedown drives I have noticed the brakes pulsating as the car slows down with brakes applied. I assumed it was rotors and checked at a local Chev dealer to see if they could be machined. Dealer service rep says sure, bring it on in, we've turned rotors on the same Vettes two and three times. I double checked with a local independent Corvette shop and was told they shouldn't be turned at all, much less two or three times, they were too thin to begin with and should be replaced.
Who is right? Can the front rotors be turned? More than once?
I am new to Vettes and to this forum, and will appreciate any advice you can give me.
Old Jan 7, 2008 | 04:09 PM
v.vet's Z06's Avatar
v.vet's Z06
Others will probably tell you but NAPA sells them pretty cheap ($25-35 each). Replacement is cheap and fairly easy! Don't have them turned.
Old Jan 7, 2008 | 04:15 PM
jovette's Avatar
jovette
Majority of members on this forum will tell you to not turn the rotors. I agree. It's my understanding that the pulsating pedal may be due to build up of brake pad material, rather than warped rotors..........
I've seen suggestions to take a vette exhibiting this condition, out to a suitable location where you can SAFELY bring it to quick hard stops from 60 + mph. It is said that doing this several times can help burn/scrap off the build up of brake pad material on the rotors. Worth a try.
If you decide to replace rotors, many forum members suggest / use replacement rotors from NAPA. A large number of members who track their cars, swear by the NAPA rotors, which are claimed to work good and be fairly inexpensive.........around $30 ea.
Old Jan 7, 2008 | 04:22 PM
Vega$Vette's Avatar
Vega$Vette
Nothing wrong with turning rotors as long as they are within specs. I suggest you pull them off and take them down to a shop like Pep Boys where if they are within tolerances turn them for about $5 each.
If you do turn them you should replace the pads when you put it back together.
BTW. I agree that pulsating is usually from a build up of brake pad material and would try the method mentioned above before I pulled them off.
Old Jan 7, 2008 | 04:32 PM
bighank's Avatar
bighank
Default Stomp On Em Hard
Most rotors pulsating are just doing that because they have accumulated too much brake material on the rotor surface.
Go to a nice straight open place where you can get the car up to 90 MPH or so. Stomp on them till you go down to about 10 MPH.
Repeat about 9 times. The brakes will be hot as hell but you should burn off the excess pad material.
Caution: DON"T COME TO A STOP with the HOT PADS or you will leave more pad material on the rotors than you started with.
Look up BEDDING the brakes on here for more info and links to other sites telling you how to do this in great detail.
My rotors were cut when I first purchased the C5. 36K miles later I decided to replace the front ones when doing the brakes. Rear ones were fine. Cost me $22.80 per rotor about 2 years ago at GM wholesaler for original GM rotors. Don't go with drilled unless you want to see them crack at the holes. BIGHANK
Old Jan 7, 2008 | 05:46 PM
Vega$Vette's Avatar
Vega$Vette
My SPORTBRAKE Drilled and Slotted have been on for 2 years with no cracks.
Old Jan 7, 2008 | 08:09 PM
Bill Dearborn's Avatar
Bill Dearborn
If you don't use your brakes hard they won't crack.
Bill
Old Jan 7, 2008 | 08:16 PM
Bill Dearborn
The dealer is right the rotors can be turned until they reach minimum thickness. The independent shop doesn't know what they are talking about if they say the rotors are too thin to begin with. Corvette rotors are thick.
However, turning the rotors is probably not the way to address your problem. The rotors should be inspected for any damage or corrosion that may be causing your symptoms. But more than likely making several hard stops as recommended above will probably work. A lot of brake problems occur because people don't use their brakes hard enough.
Bill
Old Jan 7, 2008 | 08:20 PM
cosvette's Avatar
cosvette
Default thanks
Thanks for the advice. The scraping/burning sounds like a great place to start. I'll try that first. Not sure right now where I can go to accelerate- decelerate several times so that's my next challenge.
Old Jan 7, 2008 | 08:26 PM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
Rotors are CHEAP!! You can replace them for about 60 - $100.00 ea.
(drilled and slotted). I would NOT turn them!!
To rotor question
