Wash My Engine Darn It!
Old Jan 7, 2008 | 04:32 PM
CircledWagons's Avatar
CircledWagons
From: Guess it & Win a Rock, s&h only $4.95 New Mexico
Default Wash My Engine Darn It!
Hi, I'm CircledWagons.
I am a new member with a new-to-me 2000 Pewter Coupe - my newest wagon, and I need your help.
My other wagon, a ricer has a tendency to get water in some obscure filter in the engine. So I can't wash the engine without having to take
it to the dealer and get the filter replaced.
So, as you all might imagine, I am real hesitant about washing my Vette's engine - even though it wants me to.
My questions are, is there anything under the hood that I need to be especially careful not to get water into when I wash it? And, can I use an engine cleaner foam?
Thanks.
Old Jan 7, 2008 | 04:34 PM
Drewstein's Avatar
Drewstein
I spray my motor off all the time. Just keep it away from the air filter and make sure you dry everyhting decently before starting it.
Old Jan 7, 2008 | 04:50 PM
TraceZ's Avatar
TraceZ
I always recommend against high pressure water or air on electrical harnesses. You don't want to push water into the connectors.
I like to use a hot diluted mixture of Simple Green and a long bristled brush. Use the brush to get into as many places as you can. Spray full strength Simple Green into tough places. Rinse with more warm water and hand dry with towels. Having different brushes to get into different places can also be a help.
Spraying the entire engine bay with a water based tire shine helps give it a showroom new look. After the tire shine begins drying, go over it one more time with a towel to pick up any excess.
Old Jan 7, 2008 | 04:54 PM
American Hydrocarbon
Guest
Posts: n/a
You don't want to force water where it was not intended to go.
I've done the tire shine thing b4 and it looks nice.
NO QUARTER CARWASH HIGH PRESSURE
Old Jan 7, 2008 | 07:22 PM
Speeed-Racer's Avatar
Speeed-Racer
St. Jude Donor '12-'13-'14-'15-'16-'17
The only thing to really watch is the alternator...
http://www.adamspolishes.com/t-Videos_DVD5_15.aspx
Speed
Old Jan 7, 2008 | 07:53 PM
fmuto42's Avatar
fmuto42
Default .....Just be Careful
to watch where the water goes ....... Sometimes just a bucket of water with a towel can work just as good and if you have a compressor, that is a great tool for "blowing" it off first with the airgun!!!!
ooh yeah's Avatar
ooh yeah
I look at it this way, Spraying the engine is just trying to take the easy way out. Its not a farm pickup truck take some time and wipe it down by hand. In the end you'll be a little more tired but all in all you'll be tons happier.. just my 2 cents.
Old Jan 7, 2008 | 07:56 PM
PostShawn's Avatar
PostShawn
There are always talks on these forums about the crazy electrical gremlins. Many times the cause is a plug in the engine bay being either dirty at the connection of it or loose. High pressure water can cause this. Not saying it will and that it shouldn't be used. But if you do clean that way just go around and maybe clean all the plug connections and make sure they are on there tight.
Best of luck and show clean engine bay pics when done
Old Jan 7, 2008 | 08:01 PM
Bill Dearborn's Avatar
Bill Dearborn
I spray a 50/50 mix of Simple Green and water on a cold engine and let it soak in for a while. Then I use the hose to rinse it off. This gets most of the dirt off and I use a shop towel to clean expecially dirty areas. Once I have the engine compartment rinsed I close the hood and start the car and let it idle until the water has evaporated from the engine. Been doing this for 20 years on all my cars including two C5s and haven't had any problems.
Bill
Old Jan 7, 2008 | 08:07 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Speed
Water doesn't hurt the alternator. Look where they mount one in a Beechcraft Bonanza...................right up front where it gets well washed in rain.
http://www.flickr.com/photos/thesimpleleaf/451938259/
Old Jan 7, 2008 | 08:11 PM
bgreen83's Avatar
bgreen83
i dont think you should spray the engine bay with water at all! I just wipe it down with water and simple green. You will mess something up spraying water in the engine bay.
Old Jan 7, 2008 | 08:13 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Bill
I believe it was your post I read a month or so ago about cleaning engine/compartment, followed your directions, my brother told me to be sure to cover alternator/fuse box with a plastic bag, and yep, everything came out clean and working perfectly. So thanks for that tip.
Old Jan 7, 2008 | 08:36 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
I'm always a little uncomfortable spraying water under the hood. But I also have steam cleaned a few and always stay away from air filters, alternators, carbs, and distributors as best I can.
In the 'Vette, you don't have to worry about carbs and distributors though of course.
I was curious if ya'll were removing your fuel rail covers to clean under them? Seems water shouldn't be on the coils (or whatever called).
yes/no?
Old Jan 7, 2008 | 08:39 PM
IAIA's Avatar
IAIA
Here's a good thread on engine cleaning. Recommended to keep the engine running while hosing/rinsing, so any problems can be identified instantly.
http://forums.corvetteforum.com/show...ghlight=engine
Old Jan 7, 2008 | 08:59 PM
vettesmith02's Avatar
vettesmith02
Yeah, but the propeller sends the water in a different direction... and hits it before it can hit the alternator.
Old Jan 7, 2008 | 09:04 PM
ztheusa's Avatar
ztheusa
No. The hub of a propeller is designed to direct air into the cowling for cooling.
Where do you get the idea that a prop would be designed to direct air anywhere but in the thrust line?
Old Jan 7, 2008 | 09:10 PM
renegad44's Avatar
renegad44
yes/no?[/QUOTE]
Actually when I cleaned mine, under the fuel rail covers was the dirtiest part, so yep, fuel rail covers came off, a nice spray of Simple Green, set a while, a little scrubbing and a mild rinse off, wipe down, engine start, and a small "spirited" run, to 'run' all the water off.
To Wash My Engine Darn It!
Old Jan 7, 2008 | 09:14 PM
tbaker1964's Avatar
tbaker1964
I spray my engine with Tire Shine then gently hose it off....sparkles like crazy.
Old Jan 7, 2008 | 09:20 PM
pk1's Avatar
pk1
I wash my engine at the car wash with the high pressure hose and the soap brush just like the rest of the car. Never any problems and I have done it probably a hundred times.
Old Jan 7, 2008 | 09:23 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Thanks Renagad44, when I popped one of my covers off, that seemed to be the dirtiest place so far. I would think a hosing or pressure wash would be out of the question. A "misting" makes sense.
