Blue Headlights
Old Jan 10, 2008 | 03:16 AM
Garrett W's Avatar
Garrett W
Originally Posted by Junkman2008
Wow Garrett, where have you been? There are so many HID threads describing this in detail that some of them have been locked. This one will be locked soon too because of all the references to eBay, which is a no no because there is a supporting vendor (DJ Motorsport Accessories) who sells the HID kits which will do what you're wanting to do.
Here's a picture during the installation of my HID's. They are the 6000K (just a tinge of blue and very bright). The passenger side is a HID, the drivers side is stock. Notice the difference in color and brightness. You'll kick yourself for not doing this sooner.
Takes about an hour to do the install if you know what you're doing.
Yea ive been in italy for 2 years so i havnt been on the forum in a while. thanks for the advice though ill check out that site.
Old Jan 10, 2008 | 03:21 AM
Garrett W's Avatar
Garrett W
Originally Posted by DavzC5
In this picture I have 8000k hid low beam and a Cool Blue Hologen bulb for high beam. Since then I put 8k hid in high beam also.
so you are supposed to replace both the low and high beams in each headlight? or do most people only do the low?
Old Jan 10, 2008 | 03:54 AM
Garrett W's Avatar
Garrett W
Also i dont hear of anyone getting 10k or 12k... is this cuz they dont fit or something? more lumens than the 8k in those?
Old Jan 10, 2008 | 03:55 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
Most people only do the low beams, rarely do I use the highs (especially with HID's) so it would be a waste IMO. Unless you really want to then that's up to you.
Old Jan 10, 2008 | 04:00 AM
Garrett W's Avatar
Garrett W
haha last question i promise!!!
so 880/881
or
9006?
Do most people buy both? or do they come together or what? do people get 6000k for both iuf the want 6000k?
Old Jan 10, 2008 | 05:59 AM
Junkman2008's Avatar
Junkman2008
so 880/881
or
9006?
If you want the brightest light, the 4300k bulbs are technically the brightest. The only problem with the 4300K bulb is they have a yellow tinge to them just like your stock lights do. The 6000K bulbs are extremely white also, but with with a tinge of blue. If you go higher that 6000K, you start loosing brightness and everything above 6000K has a really distinctive blue color to them. As far as I'm concerned, anything above 6000K is a waste of money if your goal is to get the best lighting possible, and anything below 4300k is just a nasty yellow light; just like your stock bulbs are now.
Most people buy 6000K for their low beams and for their fog lights (if they have fogs). Upgrading your high beams is a waste of money because you don't use them that often, and the 6000K low beams will probably eliminate your need for high beams anyway.
Did all that make sense?
Old Jan 10, 2008 | 06:07 AM
jdmvette's Avatar
jdmvette
Night Owl for life
no it's because they're too blue.
here's some pics to show you the difference:
as you can see, anything above 6000k gets WAY too blue.
of course if you want the full "arrest me" look, you can always go with 12000k all around.
Old Jan 10, 2008 | 06:11 AM
Junkman2008
Trust us, you want to go with 6000K bulbs. Don't make it complicated.
Old Jan 10, 2008 | 09:32 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Old Jan 10, 2008 | 10:35 AM
jrprich's Avatar
jrprich
so 880/881
or
9006?
880/881 are for the Fog Lights
9006 for the Low Beams
Old Jan 10, 2008 | 03:26 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
You do hids before changing to a cold air intake? What is wrong with you junkman get your priority straight LOL
Old Jan 10, 2008 | 03:41 PM
Junkman2008
Man, I'm scared to do any upgrades to that engine! I did an upgrade to my El Camino engine and now, $20,000 later, I'm still blowing up stuff. Yea, it's a beast to drive but I'm tired of upgrading stuff to handle the stuff I upgraded. It's a headless beast!
Nope, that Vette is staying stock!
Old Jan 10, 2008 | 03:53 PM
  #33
Garrett W's Avatar
Garrett W
Originally Posted by 04 commemorative
alright so from the research ive done and from what everyone here it sounds like 6000k is the way to go and i get the 9006 and there is no need to get the high beams replaced...
Only thing im confused about is fog lights someone mentioned above how you can replace the foglights "if you have them" do most poeple also do the fogs or do the just replace the low beams which are 9006?
Old Jan 10, 2008 | 04:06 PM
  #34
Junkman2008
If you have fog lights, you'll either replace them or turn them off for good, especially when you see how yellow the look when compared to your low beam HID's. They won't match or look good at all. Remember, you're only replacing the bulb, not the whole assembly (unless you buy something like the ACA kit).
Look at this Vette with both the lows and fogs changed over to HID's. See how the fogs look?
Now look at the fogs before he changed them.
See the difference? Yuk!
Old Jan 10, 2008 | 04:12 PM
  #35
Garrett W's Avatar
Garrett W
Ooooo alright. Got it! So ive ben browsing eBay... Why are some $300 and some are 80 dollars? How do i know which one to choose that isnt junk? Any advice of brand?
Old Jan 10, 2008 | 04:17 PM
  #36
Junkman2008
You can always buy them from DJ Motorsport Accessories. They are a forum supporting vendor.
Old Jan 10, 2008 | 04:18 PM
  #37
jrprich's Avatar
jrprich
IMO most of the "kits" are all pretty much the same.
I got the least expensive I could find, and would consider them disposable just like the OEM bulbs.
Old Jan 10, 2008 | 04:21 PM
  #38
jrprich's Avatar
jrprich
If you want the best headlights, get the ACA replacements with real projectors for your low beams.
$750- ???? depending on how lucky you are
