[Z06] Relationship: RPMs and MPH
Perhaps, but....
Automatic, on a hill, holding the car from rolling backwards by modulating the throttle to hold the car steady. Capture the RPM's necessary to hold the car steady.
Now, repeat that same rpm on flat level ground.
Did the rpm/mph ratio change?
On a viscous-coupled drivetrain, possible.
Not on a hard-coupled drivetrain IMO.
best regards -
mqqn
Mr. Wizard is turning over in his grave seeing this thread; didnt anybody other than me actually watch the show?!?!?!?!?!?!?!
My old Mustang = old, busted hotness (my 2003 Cobra was nothing more than a fancy 1979 Fairmont)
My (new to me) 2002 Z06 = new hotness
OK, before everyone labels me as the dumbest person on the face of the earth, I do hope ya'll realize I was kidding about the whole ride height affecting vehicle speed. I forgot the
and the
and the
How can one even try to begin to 'prove' that a given rpm would produce a different speed with a manual tranny?
I mean without tyre slippage, slutch slippage or gear mangling how would it be even possible for "the wind" to alter the mechanical relationship of the conrods, crank, clutch, input shaft, gears, outputshaft, propshaft, diff, half shafts, hubs, wheels and tyres?
Even taking into account drive line slop, clutch slippage and tyre growth/shrinkage surely the difference in rpm for a given speed will be minimal.
I dont even think mashing the gas would increase the HP at that point, as HP is a function of RPM - you need the revs to produce HP.
That other thread was almost as exciting as the QM/LG Cam thread earlier :P hehehe
The topic, as you stated it, is:
post here.
I never thought about this until I read your post, but interesting discussion.
best regards -
mqqn
Remember HP/TQ curves are just one measure of output (WOT). More rpm if it's still flowing well will make more hp, But so will part throttle cruise to wot.
Just puttin' that out there.
When you're stopped with an automatic in gear, and step on the gas, the converter is slipping.
With a manual there's no slipping (or shouldn't be any), once you step on the gas, the rpm will start to go up. Any jump is probably instrumentation. And our cars are quite powerful, the rpm will go up quickly depending on the gear you're in.
Also if you're measuring speed after some distance at wot, the mph/rpm you measure will differ depending on grade, wind, starting speed (drive out of a corner), weight, towing or not, etc. Same with top speed, it is dependant on those effect, but at 60 mph@rpm cruise it's not.
Oh, as for doing the test, the issue will be maintaining the proper throttle to maintain a constant rpm. I will also point out you can use your cruise control to show the 60 mph=x rpm, As long as you realize the control loop isn't designed to maintain exact rpm, only regulate the mph to within a few mph.
I guess my point was that given the fixed mechanical relationship of the driveline any increase in rpm must result in an increase of speed - but that an increase in throttle opening does not always result in an increase in rpm and thus not always an increase in speed.
... it's not rocket science.
