Unless you are already going 160mph and shift into 6th gear - at which time the super tall gear will have the car slowing down no matter how much throttle you use. The stock LS6 just does not have the power/torque to accelerate the wheels through 6th and still have enough oomf to move the wall of air aside.
Yes ... RWHP, aero drag + rolling resistance and gearing (which determines RWT and tangential propulsion force at the tire/road interface) are all factors in a force balance equation that will determine the "drag limited" top speed at WOT. This is a little more in the rocket science domain.
As long as there's no slip, it will be mph = x rpm [assuming the same gear], with automatic's the torque converters are made to slip under certain conditions, with manuals, with the clutch working properly, and the tires hooked up, there is no slipping.
You were right in the other thread, and you're right here.
I added a little into your response, in case someone sees that as a variable.
But through all that... the rpm / mph relationship would remain fixed.
Seems like RPM would have nothing to do with aerodynamics. At a specified speed, the wheels are turning a certain speed. The engine speed is directly related to the wheel speed, so it would not change unless you are getting more slippage between the tire and the road surface.
Tailwinds and headwinds only work on airplanes.
Tailwinds, headwinds, flight attendants, pilots, and mechanics also work on airplanes.
You probably meant tailwinds and headwinds work only on airplanes.
(Had a great english teacher in high school.) Goodbye.
Well, to "work on"
could implie that you mighten of gotten "blown off" by a flight attendant.........better to say "work inside", better chance for more of a thrilling ride............
