[Z06] 02 Z06 Rear Diff Chatter Problem
Old Jan 8, 2008 | 09:29 PM
Torched's Avatar
Torched
Default 02 Z06 Rear Diff Chatter Problem
I had my rear diff fluid changed last April. Used Redline 75/90w and 1.5 bottle of Redline friction modifier. The car is not a daily driver and has not had even 1000 miles since then but has developed a rear diff chatter when turning right clutch in and gliding around a turn.Today I had the fluid flushed and now used the GM OEM 75/90w fluid with 2 bottles of the GM friction modifier. After reading on another site some people have reported issues with the clutch packs. Is there a TSB about this issue and did I do the right thing by changing a like new fluid. I'll pick up the car tomorrow and the tech said the noise is gone. It's a independent shop not GM.
Old Jan 9, 2008 | 01:09 AM
Torched's Avatar
Torched
Somebody must have some idea of this problem?
Old Jan 9, 2008 | 02:04 AM
rustyguns's Avatar
rustyguns
too much modifier......drain it out and put in new rear end lubricant that has the modifier in it already.
FYI you will get more answers in tech section or genral section on this kinda stuff
Old Jan 9, 2008 | 04:31 PM
Torched's Avatar
Torched
I don't know about having to much modifier. I was told by C4C5 specialist that the C5 diff is particular with certain brands of fluids and could chatter for some reason and did not like the Redline products. Drove the car to day after flushing with OEM fluids and 2 bottles of GM modifier the diff was very quiet now. I'll keep an ear out.
Old Jan 9, 2008 | 04:48 PM
rustyguns's Avatar
rustyguns
i used royal purple and it worked great! not sure how good it is in an engine but in the tranny and rear end it really works well
(FYI the ballbearing test they show for it is actually for gears not engines)
Old Jan 9, 2008 | 09:53 PM
Torched's Avatar
Torched
I really can't be 100% sure if my diff did not like the redline products or not enough redline additive was used that's why I went back to OEM.I guess the only way to be totally sure is do it myself.Does Royal Purple diff fluid come with additive or did you add your own how many bottles and what brand.
Old Jan 10, 2008 | 12:29 AM
rustyguns's Avatar
rustyguns
RP HAS IT IN IT I THINK IT WAS A LITTLE LESS THAN 3 QUARTS ?
Old Jan 10, 2008 | 01:15 AM
Torched's Avatar
Torched
Thanks for that. I'll check out RP next time I change it.
Old Jan 10, 2008 | 02:04 AM
rustyguns's Avatar
rustyguns
LOOKS LIKE THIS... ENTER THE ITEM NUMBER 300175380805 IN THE SEARCH ON *BAY
THATS NOT MINE .... I GET IT AT PEP BOYS
Old Jan 10, 2008 | 02:17 AM
rustyguns's Avatar
rustyguns
http://www.royalpurple.com/
amsoil isvery good also! http://www.amsoil.com/
Old Jan 10, 2008 | 03:31 AM
longdaddy's Avatar
longdaddy
i never had excessive chatter, but I could hear it once in a while. changed to amsoil and their additive, now i hardly ever hear it.
Old Jan 10, 2008 | 04:21 AM
briann510's Avatar
briann510
Ive never experienced chatter with the gm gear oil and 1 bottle of friction modifier as recommended. Changed it once already and all is still good. I see no reason to even put some other brand in it.
Old Jan 11, 2008 | 12:56 AM
Torched's Avatar
Torched
That makes me nervous using 2 bottles of modifier to shut it up VS your one bottle. Hopefully it's not the clutch packs time will tell.
Old Jan 14, 2008 | 10:46 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Torched,
For what its worth, the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 contains friction modifier and I've never added extra in my 02 Z06 (or my 06 CTS-V which runs the same fluid) and I've never experienced chatter.
The C6 diff seems very susceptible to chatter and there are numerous TSBs out to add more friction modifier. For my C6 customers, I recommend adding one bottle of the AMSOIL Slip-Lock Differential Additive.
For the C5/C5 Z06, I recommend going with the straight Severe Gear 75w90, and only adding modifier if the diff chatters.
If yours isn't chattering right now, you are likely good to go.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To 02 Z06 Rear Diff Chatter Problem
