Scissors jack for vette
Old Jan 10, 2008 | 12:41 AM
napacruzerc5's Avatar
napacruzerc5
Default Scissors jack for vette
Wanted to change my wheels and discovered my floor jack would not go down far enough. Waz about to go down to the local Kragens when I remembered that my DD Nissan Altima has a scissors jack. And yes it fits and works great. Also looks like it will compress about 2-3 inches below stock C5 height. I'll be able to use it once I lower it - and its free!!!
I've read several threads here about getting a Jaguire or Mercedes jack from the junk yard but I bet there are a lot more Altima jacks available and probably cheaper too. Probably any import sedan jack would work.
Old Jan 10, 2008 | 02:15 AM
rustyguns's Avatar
rustyguns
i use my old 1988 mazda jack
Old Jan 10, 2008 | 02:35 AM
Nice to know about the Altima jack. Thanks for the info.
Old Jan 10, 2008 | 02:42 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Yup, Ive also used a friends rx-7 scissor jack once as well.
Old Jan 10, 2008 | 11:04 AM
4 KRUSIN's Avatar
4 KRUSIN
Thanks. I have been looking for a low profile jack as well. Maybe I should have a close look at the one in my Acura TL; Hmmmm!
Old Jan 10, 2008 | 11:11 AM
hotwheels57's Avatar
hotwheels57
I bought an aluminum scissors jack (Mazda RX7 or Porsche) for my car. It weights next to nothing, collapses down to about 3 1/2" and will lift a C5/Z06 with ease.
Old Jan 10, 2008 | 11:24 AM
jrprich's Avatar
jrprich
The jack from my 96 Eagle talon (Mits Eclipse) also works fine
Old Jan 10, 2008 | 11:51 AM
bucwheat's Avatar
bucwheat
Bought 2 at a yard sale,don't know what they went to but both work.
Old Jan 10, 2008 | 12:46 PM
jrprich's Avatar
jrprich
I would guess that if you went to a junk yard you could find many import scissor jacks for low $$ that would work.....just measure their closed height
or new for $13
http://www.mattstools.com/scissor-jack-p-3880.html
Old Jan 10, 2008 | 01:20 PM
JH's Avatar
JH
Wow! Great tip, and thanks.
Old Jan 10, 2008 | 02:20 PM
Tom/99's Avatar
Tom/99
I've had two scissor jacks that I've been using since the early 1970's. They fit under a lowered car without any problem.
Old Jan 10, 2008 | 02:51 PM
Bad97ta's Avatar
Bad97ta
i use my old 96 camaros jack. (one of the only parts i got back after it was stolen )
Old Jan 10, 2008 | 03:36 PM
Drewstein's Avatar
Drewstein
I just drive it up on a 2x4 and use the floor jack. Then I move the wood out of the way once in the air for a free workspace.
Old Jan 10, 2008 | 08:26 PM
csexton's Avatar
csexton
Good info
Chuck
Old Jan 10, 2008 | 08:56 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Some Friendly Advice
Those low profile jacks are great, I have one also but they do not work on a C5 where there is no air in the tire.. ( Not a run flat ) once the side wall collapses.. you have no room to get to the A frame and no room if you use pucks...So here is a heads up for you non run flat folks... let all the air out of a tire ( recreate a blow out in your driveway )... see if you can get that jack under there then... here is some help on this issue though... for non run flat members.. you have a compressor on board... you have to blow up the tire even though its flat in order to get a low profile jack under there... hope its not off the bead because if its flat you wont get a jack under there. ( Do a dry run ) just some friendly advice.
Bill aka ET
Old Jan 10, 2008 | 09:39 PM
speedsk899's Avatar
speedsk899
I have a Big Red aluminum race jack, it is blue though , and it fits under my completly lowered C5. I got it off Amazon for around $70
Old Jan 11, 2008 | 07:20 AM
RAO-3's Avatar
RAO-3
Bill aka ET
Definitely true - I found this out the hard way!
Check your jack to be sure it works!
To Scissors jack for vette
