Headlamp motor worn
Old Jan 12, 2008 | 04:26 PM
cubelets's Avatar
cubelets
6th Gear
Default Headlamp motor worn
Just in case someone is in need and want to replace it themselves. My 2001 right headlamp motor began making a terrible noise only when the headlamp goes down, it operated fine other than this incredibly nasty/embarrassing noise that lasted about 10 seconds. I searched and searched and found a post to replce it myself.
http://www.vetteweb.com/tech/vemp_07...amp_motor.html
In short, there is a plastic flywheel in the motor that had worn teeth. It took about 2 hours to replace and it is a very tight spot to work in, if you really want to do it with less ease then remove the entire headlamp and you could replace it in 15 minutes, having a retractbale magnet wand for picking up fallen nuts and bolts is a must. Also you will notice in the article that newer C5 models have the chamber glued in place, be carfel and just pry it with a screwdriver easily. Good luck.
Old Jan 12, 2008 | 04:35 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
This is a know prob with the Vettes and the Trans Ams,
There is a brass gear that one should replace it with, Not the plastic gear again.
Just a heads up.
