Mirror Replace Driver side help?
Old Jan 14, 2008 | 09:43 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Default Mirror Replace Driver side help?
Morning guys!
Noticed over time my drivers side mirror has discolored and you can push on it and you can see the gooey fluid inside (assuming that has something to do with the heating ?).
I have read repair threads until I am crossed eyed now. My mount is ok, I just need the mirror glass. Is there any easy fix to just replace the glass? Without removal of entire unit? i.e. pop the old glass out and plug in the new? Do not care about the heating function, motor is fine. Yes, wishful thinking
Thanks in advance!
tt
Old Jan 14, 2008 | 09:50 AM
OIF2XVET's Avatar
OIF2XVET
by no means am I an expert but the only quick fix is to get the mirror piece (i think ecklers has them) with glue or M3 tape on back and put it over the bad mirrior. you loose heat funtion but I have seen it on other vettes and it doesn't look to bad. sorry I couldn't be of more help but someone will chime in shortly.
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Ifi remember correctly, there's a whole lot of tugging involved. The mirror is secured by two "ball-in-socket" joints There's also 2 wires connected to the mirror itself for heating I think.
Old Jan 14, 2008 | 09:56 AM
OIF2XVET's Avatar
OIF2XVET
I had a sec so I looked it up for ya. Ecklers has what you may be looking for, it is a mirror with self adhesive on back. looks factor and fits over existing mirror. cost is 49.99 and the item no# is 50800. sorry can't post pics cause I am @ work but I am sure this will get you the results you are looking for. good luck let me know how it turns out for ya.
Old Jan 15, 2008 | 09:23 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Thanks guys!
Old Jan 15, 2008 | 09:26 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Went to Eckler's, out of stock Appreciate the help though.
At GM direct the replacement is $39, Fred Beans $47. May give it a try and hopefully not create more work for myself
Thanks again!
To Mirror Replace Driver side help?
