You'll probably get flack on this from people saying that these are for ricers. But if you like them it's your car so go for it. But they are way over priced. You could do the same thing for a lot less money using LED strips. Here's a link http://www.oznium.com/flexible-led-strips
....Save a lot of cash and get them from 'Oznium.com'.... ....I've purchased from them recently and would highly reccommend.....
Do you need an LED Controller to operate these? If so, which one? Anyone set them up to work as turn signals, similar to the side mirror light turn signals would work?
No you don't need a controller to use these, unless you buy the kind that change colors. Just an On/Off switch
I was thinking about adding some to my ride and wiring them into the fog light switch. Yep, call me Uncle Ben.
I've had mine on my Vette for about four years now. Originally had small NEON tubes there but have switched to the LED strips. Tied them into the fog light switch. Best thing about that too is that when the "approach lights" feature is turned on, the LED's light up when I press the key fob in a parking lot to unlock the car. Neat effect!
any writeups on this? wiring to turn signals? by doing that they light up when u unlock the car as well? Can you have them light up with you headlights at night and blink with ur turn sig?
