Question about "Euro headlight" conversion
Old Jan 17, 2008 | 10:52 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Question about "Euro headlight" conversion
For those of you that have done the Euro headlight conversion, did you have any problems with the headlights not going down? I installed a set on my mom's 98 vert and found that with the engine off, the headlights will go up, but not down. (the motors dont' even try to turn) However, with the car running, the headlights will go up and down.
I've heard this may have somthing to do with the headlight circuit not getting the correct voltage signal. Since the high wattage headlights require a relay, they're not connected to the OEM headlight terminals. They just tap into the headlight power wire for a signal lead.
Old Jan 30, 2008 | 08:20 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Did you ever get this problem figured out?
Old Jan 30, 2008 | 10:21 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
no, the problem still exists. But given that the car is not driven that often, it's a quirk that i'm willing to over look. As long as the car is running when the lights are turned off, they'll go down.
...however, if you have a solution, i'm all ears.
Old Jan 31, 2008 | 05:01 AM
FinnZ06's Avatar
FinnZ06
I'm going to get mine installed this spring. I'll let you know how they work on my car when I get them installed.
Old Jan 31, 2008 | 05:09 AM
Choreo's Avatar
Choreo
I installed mine almost 3 years ago (from PFYC). I had trouble immediately with my right headlight staying up most of the time when I would turn the lights off. I contacted PFYC and they said this was a known issue and sent me some sort of in-line electrical plug that I added in the line up by the right headlight harness. Everything has worked perfect ever since.
They did not charge me for this part at the time. I have the HD Harness with the two relays added.
These headlights are awesome!
Old Jan 31, 2008 | 04:21 PM
DeeGee's Avatar
DeeGee
Never had any problems but I used the PFYC plug and play harness with the hi wattage kit with the relays
Old Jan 31, 2008 | 04:24 PM
thetaxman's Avatar
thetaxman
I got mine from LAPD years ago
I never had the problem you mention
To Question about "Euro headlight" conversion
