double din mod help
Old Jan 17, 2008 | 08:08 PM
rollinred's Avatar
rollinred
Default double din mod help
i am starting the double din mod i need help from you guys who installed your own how did you guys remove those brackets on the inside that the stock radio sits on.
Old Jan 17, 2008 | 08:15 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I drilled them out with an angle headed drill attachment to my Dremel.
Old Jan 17, 2008 | 08:18 PM
Bell's Avatar
Bell
I haven't done this mod myself, but I have read a number of threads where others have done it. It seems the that the bracket is riveted together and it requires some tactical drilling and lot's of cussing. If you can't get at it, then your not cussing right.
Old Jan 17, 2008 | 08:20 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
took about 20 seconds for both sides
Old Jan 17, 2008 | 08:23 PM
rollinred's Avatar
rollinred
thank you i am going to get that saw tomorrow you saved me a lot of time
Old Jan 17, 2008 | 08:26 PM
0Double D Mods
Former Vendor
your welcome, its worth every penny
Old Jan 17, 2008 | 08:29 PM
rollinred's Avatar
rollinred
did you use the top bracket by turning it up side down to support the double din
Old Jan 17, 2008 | 08:36 PM
0Double D Mods
Former Vendor
yes thats exactly what was done. We drilled holes into the bracket and into side of the cage and remounted back in upside down. You will need to then mount the radio cage to the bracket. You wont be able to use any kind of bolt with a very large head on it or you wont be able to slide the head unit into the mounting bracket. We found out the hard way
Old Jan 17, 2008 | 08:41 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Dennis...very I wasn't around when my shop installed my double din unit but your past few posts here clearly shows how it was done ...good thread for future reference
Old Jan 17, 2008 | 08:42 PM
rollinred's Avatar
rollinred
p.m. sent
Old Jan 17, 2008 | 08:46 PM
Bob CTS's Avatar
Bob CTS
I figured that pic would show up, gives me the creeps looking at it.
Old Jan 17, 2008 | 08:51 PM
0Double D Mods
Former Vendor
I cant take all the credit. I had Pentavolvo and DPG helping me as well since they were the install experts.
But I was the one who got tired of drilling and went to the hardware store for the bug guns
This is the easiest way to do it
bmw2nv2000's Avatar
bmw2nv2000
I gotta get around to doin a dd install sometime. you guys make it look and sound halfway easy . I personnaly think c5 BearsFan should do a complete write up and pcs about his install .
Old Jan 17, 2008 | 08:52 PM
0Double D Mods
Former Vendor
Yea I was a little freaked taking that baby to my pride and joy
Old Jan 17, 2008 | 08:56 PM
cletus's Avatar
cletus
You can get lots of exact instructions if you go to: "Corvette General" under the "Forums" tab and then go to Audio/Electronics. Then do a search for double din. The members over there are incredibly helpful and knowledgable. That's how many of us did the mod including me.
Old Jan 17, 2008 | 08:57 PM
0Double D Mods
Former Vendor
here was the original write up by Pentavolvo the one who needs the credit. I was there to help but Greg is the master at doing these installs.
http://forums.corvetteforum.com/show....php?t=1687832
Old Jan 17, 2008 | 08:58 PM
0Double D Mods
Former Vendor
To double din mod help
Old Jan 17, 2008 | 09:03 PM
rollinred's Avatar
rollinred
thanxs sent you another p.m.
Old Jan 17, 2008 | 09:05 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ok a few things guys as far as putting the bracket back in to support it its not a must but its recommended. As far as mounting the unit and I didnt do this with dennis' car get some l brackets or osme metal u can bend. Slot one side so you can adjust em and put em in the din holes in the side of the radio and bolt her up to the metal frame/dash how the stock one was. This should make it alot easir. Some guy did it that way I dont remeber who put genera/audio has lots of good info
Dave98's Avatar
Dave98
I just sent my console to the C5 KIDD, so now I'm patiently waiting for it's return before I start cutting. Maybe I'm being overly cautious, but I wanted to make sure it fits with the new console.
