Help. Installing sidemarker BULB only. :)
Old Jan 18, 2008 | 04:40 PM
CharlieB1979's Avatar
CharlieB1979
Default Help. Installing sidemarker BULB only. :)
As says in the title. I removed the outermost taillight and looked in, saw the connection to the sidemarker..but don't know how to remove the bulb. I just need to replace the bulb.
I want to be delicate....figured i'd run it past you guys first, you guys know better than I do.
Thanks in advance!
Old Jan 18, 2008 | 05:07 PM
DeeGee's Avatar
DeeGee
You remove the lamp unit by rotating it counterclockwise in the housing. Once you pull it out of the housing you can get a the bulb. Its a 194
Old Jan 18, 2008 | 05:09 PM
CharlieB1979
So I reach into the vette through the rear taillight, take hold of the housing that's going into the sidemarker, turn counterclockwise and pull?
Old Jan 18, 2008 | 05:13 PM
DeeGee's Avatar
DeeGee
Spot on
To Help. Installing sidemarker BULB only. :)
