Tint Problem
Old Jan 20, 2008 | 10:10 AM
JustinZook's Avatar
JustinZook
Default Tint Problem
i have a 04Z.I just got my car tinted and they had a problem with the back window. they said there were many "pits" in the back window. JUst little indentions in the glass. they said it is a defective glass from the manuf. ANyone else run into that problem? The installers said it wasn't common in chevy's but see's it in alot of fords.
JustinZook's Avatar
JustinZook
Old Jan 20, 2008 | 10:16 AM
DeeGee's Avatar
DeeGee
I've seen posts where theres been a problem applying tint over the "dimples". Never heard of pitting though. Sounds like a shop who's trying to cover something (forgive the pun )
Old Jan 20, 2008 | 10:18 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Never heard of that ... I'd be suspicious about that story
Old Jan 20, 2008 | 10:23 AM
JustinZook's Avatar
JustinZook
when they discovered the pits the took me back in the shop and showed me.. they ran a razor blade over the window and it made severe scraping noises only on the back window due to the "pits". he also said there were tiny pieces of glass on top of glass. it was just what i wanted to hear...NOT
Old Jan 20, 2008 | 10:26 AM
Junkman2008's Avatar
Junkman2008
Like DeeGee said, some shops will have a problem dealing with the dimples in the back window. If they know what they are doing or are truly experienced in tinting, they will be able to overcome this dimple issue. Just as with the Corvette Forum, there are tinting forums on the Internet. I have throughly read through this problem and here's the bottom line: if your shop cannot get past the dimple issue, then you're dealing with some rookies. There are a few recognized methods to get past the dimples and the guys who know what they're doing have figured it out.
Basically, they fed you a story to make up for their inadequacies.
Old Jan 20, 2008 | 10:45 AM
JustinZook's Avatar
JustinZook
i guess that's it then. i did a little bit of research before going with this shop.. they are well known and and well liked.. guess they are not what everyone thinks.
Old Jan 20, 2008 | 11:00 AM
georgec114's Avatar
georgec114
I'm not so sure...Glass has defects like anything else. You could also
have glass that is etched. Years ago when I had a Supra, I used one
of those acid based wheel cleaners on my windshield.
It distorted the surface enough where I had to replace it.
Pitting isn't uncommon on the windshield due to road debris and
particularly for those in sandy areas. The rear window?...I dunno' ?!?!
Old Jan 20, 2008 | 11:38 AM
JustinZook's Avatar
JustinZook
yeah it was the rear window inside the car...... i dunno either
Old Jan 20, 2008 | 11:41 AM
DeeGee's Avatar
DeeGee
I'd say the best idea would be to take it to another shop and ask for asecond opinion. If it is genuinely a bad piece of glass they'll be straight with you. Then have a go at GM
I had tint on my Camaro when I was in San Antonio. It peeled badly because it had been put on over the dimples. It never was right and the moisture in England made it worse.
Old Jan 20, 2008 | 11:56 AM
BLUETHUNDER_06's Avatar
BLUETHUNDER_06
If there are defects in the glass,then the film wont cover it.By running the blade over the glass,he has shown you that there are raised pieces in the glass that the film wont cover.I dont think he has spun you a line,because he has actually shown you what the problem is,where most tint shops wont.The other place on windows where tint has a real tough job applying is around the dot matrix.It is near enough impossible to apply here as the film on gets trapped between the gaps and cant be pushed out.
Old Jan 20, 2008 | 12:32 PM
Junkman2008
If the glass is bad, then I agree. But I'm betting that the "pits" they are talking about are the dimples in that black trim that goes around the window. Anyway, how do you get pits on the inside of the window? I like DeeGee's advice, get a second opinion from another tinter. Ask them if they can fix it and whether or not they think that it was a bad tint job.
Old Jan 20, 2008 | 12:38 PM
oaks99's Avatar
oaks99
the only place that most tint shops have are the black spots , and they should really only go into them about 2-3 rows ,
so to answer they are filling you full of s##t
oak
Old Jan 20, 2008 | 12:49 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Call Pro Tint in Plano Tx!
Ask for Claudio, he has done many Corvettes including mine and no problem in 5 years! !
Old Jan 20, 2008 | 03:45 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I believe the tinter I used put black vinyl over the dot matrix areas....
Old Jan 20, 2008 | 04:35 PM
XXXLTRP's Avatar
XXXLTRP
Yep. Thats the route my guy was going to as well, but after a few days he told me to run my fingers up toward the roof. I got rid of 99% of what looked white from the outside. Had that not worked he was going to use black vinyl from the bottom of the dot matrix up. It would not be noticed from the inside, the highest I can see from the inside is the top line for the rear defroster.
Old Jan 20, 2008 | 05:26 PM
mrm1149's Avatar
mrm1149
Exactly. That's why it works well, glad you got the "specks" out of your tint though....sure keeps the inside cooler in the summer, doesn't it? Lotta glass area back there.
Old Jan 20, 2008 | 07:01 PM
Z06wanted's Avatar
Z06wanted
I am a Professional window tinter for 11 years now. It is dot matrix at the top of the window. It is near impossible to make it look good. After it's tinted a few days later you can go back and push it down for the most part. As for specs on the glass I would look into the car being recked and the glass not be takend out when worked on. I have seen welding splatter on glass before. Any more questions about it pm me.
To Tint Problem
