[Z06] Widest Tires
Old Jan 20, 2008 | 11:54 AM
SilZ06's Avatar
SilZ06
Cruising
Default Widest Tires
I have a 2003 Z with 20 by 12 Z06 motorsport rims. I am wondering what are the widest tires I would be able to put on without using spacers.
Old Jan 20, 2008 | 12:04 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
I would think 335's
Old Jan 20, 2008 | 12:14 PM
SilZ06's Avatar
SilZ06
Cruising
i know that the 12 inch rim would fit 335, but still would i need spacers or just throw the tire on the rim and put it on the car.
Thanks for the information
Old Jan 20, 2008 | 12:34 PM
PeteZ06's Avatar
PeteZ06
Youde have to remove your brake ducts. It matters with the offset but most likely a spacer would be needed.
Old Jan 20, 2008 | 04:21 PM
SilZ06's Avatar
SilZ06
Cruising
i was told that i could do a 315 on the rim without using a spacer or taking the break ducts out
can anyone vertify this ?
Old Jan 20, 2008 | 07:26 PM
PeteZ06's Avatar
PeteZ06
The 315 is not your issue, the 12" wide wheels is. My friend is running a 19x12 wheel with 325's. He needed a spacer. But the wheels are pretty flush with his quarters.
One of the sponsors here sells the 18x12 wheels, no spacer needed but they stick out about an inch.
So it all matters on which wheel you plan on running and what offset.
Old Jan 20, 2008 | 08:33 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
Tommorrow is MLK day, I don't think an "all white Z06" forum is wise.
Old Jan 20, 2008 | 10:25 PM
PeteZ06's Avatar
PeteZ06
Since when did they make white Z06's in '03?
Hello newbie
Old Jan 20, 2008 | 10:31 PM
Davinss's Avatar
Davinss
A 315 will fit on the stock rim, no rubbing or modification at all.
Old Jan 21, 2008 | 12:40 AM
Rickyh93's Avatar
Rickyh93
Hello newbie
Come on Pete, we both know white is the best
Back on topic though. I think you could run a 335 tire back there. If you didn't want to run a spacer you could always tub it. I plan to do that if I need to run larger tires. Although I guess I could go with the WC flared fenders instead of tubbing.
Old Jan 21, 2008 | 09:17 AM
AU N EGL's Avatar
AU N EGL
My street wheels are 18x12 with 335/30x18 Mich PS. They rubbed the inside of the wheel well out.
Old Jan 21, 2008 | 09:25 AM
Bigstik's Avatar
Bigstik
Hello newbie
his profile says quick silver!!
Old Jan 21, 2008 | 03:47 PM
SilZ06's Avatar
SilZ06
Cruising
the car is quicksilver, it looks white in the picture because of the lighting, it was taken in the summer on a sunny day
Old Jan 21, 2008 | 08:17 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
Sorry, my eyes are bad so missed the Silver, but I really do like the White Z06's, very clean look!
Old Jan 21, 2008 | 09:56 PM
White_Lightning's Avatar
White_Lightning
would a mini tub take care of that rub?
To Widest Tires
