[Z06] Underdrive pulley question?? need help
Old Jan 20, 2008 | 08:11 PM
outlawten5's Avatar
outlawten5
Default Underdrive pulley question?? need help
Will the underdrive pulley from an '04 GTO fit an '02 Z06? Are they interchangable? I am looking at an ASP pulley if that makes a difference.Any info would be appreciated.
Old Jan 21, 2008 | 03:15 AM
Last C5's Avatar
Last C5
The F body pulleys are not interchangeable with the C5, so my guess would be that the GTO pulley isn't interchangeable either. It's a matter of lining up all the accessories. Check the stock numbers for both on oem pulleys.
Old Jan 21, 2008 | 01:16 PM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
Comparing part numbers on the SLP web-site, the C5 pulley is a different part # than that of the GTO. On top of that, the GTO pulley needs 2 shorter belts, the C5 only 1.
My answer would be no.
Old Jan 21, 2008 | 01:31 PM
NytmereZ's Avatar
NytmereZ
I have an ASP pulley off my 01 Z06 if you want to buy it cheap, I dont have the belt, but the pulley is perfect(under 2000 miles on it), $120 Shipped if you want it, PM me.
Old Jan 22, 2008 | 10:41 AM
outlawten5's Avatar
outlawten5
Nytmerez, tried to send you a pm, your box is full. I'll try again after you clear a few messages out. thanks.
Old Jan 22, 2008 | 11:19 AM
NytmereZ's Avatar
NytmereZ
PM'ed you
To Underdrive pulley question?? need help
