[Z06] C5 vs Z06 Weight
my c5z was 3046 at HRP scale essentially hitting reserve light
same car with cam, lt's, stinger catback, ccw drag pack and passenger seat pulled....same fuel level and scale...2999
showroom stock c6z with 1/3 tank was 3115 (scale seemed to register a bunch more cubes as well )
Supporting Vendor
Received 2,316 Likes
My 2002 C5Z with C6Z brakes (lots more weight), 18x11's on all four corners, pfadt featherlight coilovers, oconnel sways, AR headers, x pipe (no cats) modded Ti, stock interior and exterior body weights 2989 with approx 1/4 tank.
ArmchairArchitect (12-03-2018)
Apples to apples. Curb weight includes a full tank of gas, which weighs about 120lbs
So if you're missing 3/4 tank, add 90lbs
When they are talking about the factory curb weight--no gas that are measuring the car without any options. Most of the C5 coupes came from the factory weighing considerably more than the factory minimum weight while the Z, with very few options, was closer to the factory weight.
Received 3,812 Likes
St. Jude Donor '03-'04
The Z06 windshield is 1/3 thinner.
ON a side note, ( a little insider information )... At GM, once the initial design was approved, any revision to an existing design had to weigh less than the original design it could not weigh more.. I had several revs designed that were not approved because they did not save any weight.
Bill aka ET.
Bill aka ET.
The following 4 users liked this post by Evil-Twin:
Regardless, if one measures with 1/4 tank, next with a full tank...
Another variable is the actual scale.
Then there are base models equipped differently.
My 04 Z16Zwas 3080 or 3090 years ago with a full tank at the track. I've since added headers, catless x, and swapped dual fans for a Small single.
Supporting Vendor
End of the day, C5 Z06's running around are 3050 basically, with typical fuel. I'd like to get my cars weight down further with eliminating the air pump, and getting new seats. With the audio system being dated, I feel like doing a tablet as the double din, and changing speakers may leave 10lbs in the audio system to be gained also. I also have an attack plan on headlights coming up that should get me some weight. I'd really like to see the car at 2900 with 1/2 tank. My old S2k was like 2880 with 1/2 fuel, so I feel like catching that car would be a triumph.
