[Z06] C5 vs Z06 Weight
Jan 20, 2008 | 11:00 PM
C5 vs Z06 Weight
I wanted to get an idea of what the average weight of the Z06 vs C5 when going to the track or scales.
Jan 21, 2008 | 05:53 AM
C5 Z06? vs C5 coupe? I think it's about 150lbs or so.
Dan
Jan 21, 2008 | 07:23 AM
Jan 21, 2008 | 09:28 AM
Quote:
Originally Posted by
madmatt9471
So are these stats curb weight, or is this what you can expect to see on the scale ?
Jan 21, 2008 | 10:29 AM
The C5 will be a little lighter if you've replaced your stock runflats. They are several pounds heavier than non runflats, which the Z06 did not have. Hey, every little bit counts
Jan 21, 2008 | 10:37 AM
St. Jude Donor '08
Biggest weight difference is the tires, lack of sound deadening and lighter windshield.
Z06 had non-flats.
Jan 21, 2008 | 10:39 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Yes! That is unladen or curb weight!
You will need to factor in your weight as well as fuel - At the very least!
Thanks,Matt
Reason: add "n"
Jan 21, 2008 | 10:44 AM
Those are curb weights.
Jan 21, 2008 | 10:50 AM
ajg1915
Z06 had non-flats.
Dont forget about the exhaust as well.
Jan 21, 2008 | 01:53 PM
ajg1915
Z06 had non-flats.
Uh, not to mention the inherently-lighter FRC body-style!
Jan 21, 2008 | 01:58 PM
CI 3-5-6-7-8 Veteran
FRC rear glass and trunk lid combo work out to weight less than the coupe's hatchback piece as well.
Jan 21, 2008 | 02:13 PM
TheDVS1
Pass side elec seat adjuster, if so equipped, none on z.
I'm surprised that it's only about 150 lbs, would have guessed 200 to 250.
Jan 21, 2008 | 10:34 PM
weight
the z06 also has a smaller battery to save weight .
Jan 23, 2008 | 07:15 AM
What about an 04 z16 with the carbon fiber hood ???
Jan 23, 2008 | 08:31 AM
I have a 2004 coupe and a 2002 Z06 that I'm building as a track car. Having weighed both of them (while corner weighting), the Z06 is approx 200 lbs lighter.
Jan 23, 2008 | 09:31 AM
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
My Z06 at the track (Byron Dragway, Illinois) weighed 3060lbs with about 3/8's tank of fuel, I do have a stealth box (subwoofer) in the trunk that weighs approximately 30 lbs. I have longtubes and no cats on the car as well so I would guess that equally offsets the weight of the sub box.
Jan 24, 2008 | 10:25 AM
555ss
Mine weighed 3030 on the scales at Silver Dollar Raceway with around a 1/4 tank.
Jan 26, 2008 | 09:39 PM
Don't forget the Ti exhaust and the Ultra light Wheels.
Jan 29, 2008 | 11:43 AM
It's not 150 lbs. It's 128 lbs. That's curb weight. Corvette action center info.
Jan 29, 2008 | 02:24 PM
The ZO6 does not have the telescopic steering wheel, and no electric antenna and multi cd player and the trunk well covers and the z comes with helium in the tires.
