Driving modes - no difference?
Old Jan 21, 2008 | 11:17 AM
dave from texas's Avatar
dave from texas
Default Driving modes - no difference?
On my 98 - the three switch driving mode doesnt make any handling different that i can tell. Would my suspension be old or is it a shock thing?
Thanks in advance!
Dave
Old Jan 21, 2008 | 11:20 AM
mcgilles's Avatar
mcgilles
I can't tell at all when switching mine either. from what I understand that's just the way it is. apparently the newer F55 version which is found only in the latest year or two of the C5 is better refined, you can actually tell the difference in the car's handling ability when you flip the switch. on the older F45 systems, they all feel the same to me!
Old Jan 21, 2008 | 09:33 PM
RonJ's Avatar
RonJ
I had a 98 for a short time and I couldn't feel a difference switching through the different ride modes.
RonJ ...
Old Jan 21, 2008 | 09:38 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Here's an article that you might find interesting on the new for '03 F55 suspension - but it talks about the history of the cockpit adjustable suspension options including the F45 Selective Real Time Dampening.
http://www.corvetteactioncenter.com/...s+the+50th+Car
Old Jan 21, 2008 | 09:42 PM
Dominic Toretto's Avatar
Dominic Toretto
I also noticed this! I figured maybe it was just me and never posted. I have an 01, which system is that?
-Alex
Old Jan 21, 2008 | 09:49 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
On my 99 Coupe I noticed the difference on mine, but then it was slammed and would have kept the shocks but one decided it had seen better days so on went Koni FSD shocks
Old Jan 21, 2008 | 09:54 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
I test drove a 99 Vert with the selective ride option. I couldn't feel any difference either. I thought it was just me.
Old Jan 21, 2008 | 09:56 PM
Dominic Toretto
I also noticed that there is nothing in the DIC for when I change the settings. I was beginning to wonder if my actually has it or if the previous owner just swapped the panel to look cool LOL.
Old Jan 21, 2008 | 10:35 PM
darb21's Avatar
darb21
Default Can't feel a difference? Try this...
There really is a difference. Not very noticeable, but it is there. Touring is softer, and performance is harder. To feel the difference for yourself, go out and find a series of decent bumps in the road... I've noticed it most on bridges where there is a pretty good size expansion joint that you really feel when driving over it... drive over the bridge in Touring, then do it in Performance. Performance is DEFINITELY firmer... the shocks simply do NOT cushion as well (ie. they are stiffer). Try entering the bridge on Perf., then switch to Touring while you're still on the bridge before you go over the other joint. There is a difference!
Now as for feeling a difference while spirited driving, well, I always have mine set to Perf, but I know its working. How much its actually doing (helping).... I can't say exactly. When I go out with Peter Pan and the rest of the Lost Boys out in the Texas Hill Country, I always switch it to Perf. But twice now, I've left the switch set to Perf. and noticed it was stiffer than normal on the way back home... both times I've noticed it when crossing bridges... switch it to Touring, and sure enough, its softer again.
Old Jan 21, 2008 | 10:56 PM
R Devil's Avatar
R Devil
I have it on my 98 and assume it works but it's really hard to tell much of a difference.
Old Jan 21, 2008 | 11:04 PM
johnson-rod's Avatar
johnson-rod
When I bought mine in October, I didn't see much difference in the 3 suspension settings. I figured it was just marketing hype. Then the dealer had to do some work on it and had to pull the battery cable. When I got it back WOW! Everything worked better; the 3 suspension settings, the speed volume in the radio and the dash lights. Even the heater worked better after a re-boot.
If you don't notice much of a difference in the suspension settings try pulling the negative cable off the battery for 10 minutes or so. It is the cheapest fix you'll ever do. I've done some other maintenance that required the cable disconnect and it still makes a difference.
Old Jan 21, 2008 | 11:08 PM
Ishams00vette's Avatar
Ishams00vette
Weird... I dont notice anything either. I believe the Vettes that have this are the more expensive though.
Old Jan 21, 2008 | 11:11 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I test drove a 2001 vert before I got my car which does not have the adjustable suspension option.I tried everything in that vert, on winding roads, over bumps, fast and slow, but I couldn't really see any noticeable difference. I thought it was just that particular car, but after seeing what everyone says here, maybe there really isn't much difference. Actually, I know someone who got rid of those shocks, and put in regular high performance shocks, and had to reset the computer to compensate, but seems to like the car better now.
Old Jan 21, 2008 | 11:12 PM
RedRiderZR1's Avatar
RedRiderZR1
I did this as well. Normal driving around I don't notice, but go over a series of bumps and change the settings and I can "feel" the difference. The suspension also dampens depending on your driving conditions. I'm figuring thats why I don't notice when everyday driving. But spirited driving I can tell. Especially on bad roads.
Old Jan 22, 2008 | 02:40 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I never noticed a difference until I moved, and right down the road is a section, about 100 meters long that is mildly washboard and so I tried the settings a was able to feel the difference.
Old Jan 22, 2008 | 03:35 AM
Bracketman's Avatar
Bracketman
Come to Alberta - you'll feel the difference
Old Jan 22, 2008 | 04:14 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Thats funny, I picked my car up in Edmonton (lived in Fort St. John), but I never played around with the settings.
I just left it on 'Tour' 'cuz the roads suck big time.
To Driving modes - no difference?
Old Jan 22, 2008 | 07:36 AM
VET IT B's Avatar
VET IT B
Try this and if everything is working you will feel the difference.
If you can't tell, seat of the pants, there is something not working. Mark
Old Jan 22, 2008 | 10:51 AM
capehorn3's Avatar
capehorn3
Only time I've felt a diff. is when hammering down to pass on a 2 lane, car doesn't jump up as much, is firmer to the ground. I will try the bridge expansion joint thing tonight, new interstate bridge opened.
R
Old Jan 23, 2008 | 11:24 AM
Dominic Toretto
Hhmmm, guess it's just one of those nifty gifty features I will probably hardly use. Especially on sucky Dallas roadways.
-Alex
