Driving modes - no difference?
Old Jan 23, 2008 | 04:07 PM
DeeGee's Avatar
DeeGee
I have the F45s and really theres no difference in the 3 settings
Glad I didn't pay for the mod
Old Jan 23, 2008 | 06:00 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
I can tell a huge difference in my 99 between the softest and firmest settings.
I use the firmest setting on smooth highways when cruising around 70 because it really stiffens the ride up. 70 mph on the soft setting is almost scary because the steering wheel is "floaty".
Around town I definitely use the softest setting, as it is much more forgiving with bumps and potholes.
Old Jan 23, 2008 | 11:08 PM
914eener's Avatar
914eener
On my 99 when I go from tour to performance there is definately a difference. The car has a lot more rebound control.
Old Jan 24, 2008 | 09:18 AM
hayman's Avatar
hayman
I notice less front end sway when in perf mode going around hair pin turn quickly.
Old Jan 24, 2008 | 09:28 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Originally Posted by darb21
There really is a difference. Not very noticeable, but it is there. Touring is softer, and performance is harder. To feel the difference for yourself, go out and find a series of decent bumps in the road... I've noticed it most on bridges where there is a pretty good size expansion joint that you really feel when driving over it... drive over the bridge in Touring, then do it in Performance. Performance is DEFINITELY firmer... the shocks simply do NOT cushion as well (ie. they are stiffer). Try entering the bridge on Perf., then switch to Touring while you're still on the bridge before you go over the other joint. There is a difference!
Now as for feeling a difference while spirited driving, well, I always have mine set to Perf, but I know its working. How much its actually doing (helping).... I can't say exactly. When I go out with Peter Pan and the rest of the Lost Boys out in the Texas Hill Country, I always switch it to Perf. But twice now, I've left the switch set to Perf. and noticed it was stiffer than normal on the way back home... both times I've noticed it when crossing bridges... switch it to Touring, and sure enough, its softer again.
Old Apr 18, 2008 | 01:09 AM
Bloodvette's Avatar
Bloodvette
its very hard to feel the difference, I couldn't differentiate until I tested mine on a highway where there was those cracks that they fill with tar, and if you find a consistent section of these.... drive for a while in performance, you feel a clunk and the vehicle hops a little at each crossing. drive in that mode for 30 seconds then switch to touring. seems like you hear less of a clunk, and the vehicle doesn't bounce or hop.... but this difference is so faint, that if you didn't have this feature you wouldn't miss it. Certainly not worth the $1700 option. does anyone want to buy it from me... haha, I'll give you a deal $1650. jk
however, my testing, and the testing so far from most people who commented, has been on the straight aways... Maybe this feature is more contrasted in other driving conditions- like Hayman described.
Old Apr 18, 2008 | 01:11 AM
LiquidDI's Avatar
LiquidDI
I can't feel a difference on my 05 C6 so don't feel bad
Old Apr 18, 2008 | 01:12 AM
DeeGee's Avatar
DeeGee
I'm in agreement with the crowd
My SRTD switch is redundant. If I'm on a bumpy back road the hard settings make the bumps transmit harder into the cockpit but no discernable difference in handling even on the twisty backroads in England.
Never driven it but I hear the F55 is a big improvement.
Old Apr 18, 2008 | 01:32 PM
Yoggi's Avatar
Yoggi
Ive never been able to feel any differences either, but, apparently the car does.
Old Apr 18, 2008 | 02:02 PM
rcarl's Avatar
rcarl
I have an `03 AE with the F55 and there is a very discernible difference, even at and maybe especially at lower speeds. My home street is very badly in need of repair, having gone through new water pipe installations over the last year. Travelling at 10-15 mph in the tour setting the front spoiler takes a beating, but in the sport setting it doesn't. At higher speeds on a smooth road I love the sport setting, but when the going gets rough the touring setting smoothes the road. As noted above the Corvette Action Center article is a great read if you want some in depth info.
