How much fluid does the trans and diff hold?
Old Jan 23, 2008 | 02:01 PM
Wicked99's Avatar
Wicked99
Default How much fluid does the trans and diff hold?
Im getting some RP fluid for my 99 coupe. Just wanted to know how much the 6-speed transmission and rear diff hold. Thanks for the help.
Old Jan 23, 2008 | 10:47 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
If you check over in the CF Tech section you will probably either find this info or someone will help you very quickly. Good luck!
Old Jan 23, 2008 | 11:58 PM
IM28702's Avatar
IM28702
You'll want to double check on the capacities, but as I remember, the tranny takes 3.6 qts, and the diff 1.8. Just remember to use ATF in the tranny, and a good gear oil designed for limited slip applications in the diff. If you have a 2000 or earlier, synthetic ATF is not recommended as the older trannies use paper backers on the synchros that don't last long with synthetic fluid.
To How much fluid does the trans and diff hold?
