changed to the red optima but?????????
Old Jan 26, 2008 | 05:21 PM
rmbtowing's Avatar
rmbtowing
Default changed to the red optima but?????????
its to small of course to be bolted down with the rubber wedge gm has in there. What are the best options for mounting it? Not really into the billet plate and not much of a chrome guy. What are my options?
Old Jan 26, 2008 | 05:31 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Sorry, can't help you with an answer but would like to know what the boys come up with here
Old Jan 26, 2008 | 05:34 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I had the same problem with the Exide 60 I replaced my OE with. I recently added an acid absorption mat and that brought the battery up enough for the stock hold down clamp work as it should. I know you don't need the mat but for around four bucks it worked for me.
Old Jan 26, 2008 | 05:46 PM
motogib1's Avatar
motogib1
Which one did you buy? I have an optima red top part no 8022-791 and had no problems bolting it on.
Old Jan 26, 2008 | 06:05 PM
hotwheels57's Avatar
hotwheels57
Check with OPTIMA directly or one of their local distributors. I have a red top from COSTCO with the combination top and side terminals. It fits my '04 Z16 oem battery tray w/o any issues.
http://i114.photobucket.com/albums/n...r011808010.jpg
There are some available optional brackets available that you might need if you purchased the incorrect battery for your application. They shown in this PDF file.
http://www.optimabatteries.com/_medi...s/adapters.pdf
Old Jan 26, 2008 | 06:17 PM
rmbtowing's Avatar
rmbtowing
looks like it doesnt matter which red top you have the dimensions are the same according to optima. Mine has side mount terminals and the top mount but the car is side mount (does that make any sense) The second link by hotwheels looks like it might work for what i need
westez's Avatar
westez
Send an E-Mail to Optima and they will send you a new wedge adapter to tighten it up....I did this and they sent me one free...
Old Jan 26, 2008 | 06:25 PM
rmbtowing's Avatar
rmbtowing
Just sent off the email to Opitima thanks for the advice
Old Jan 26, 2008 | 06:40 PM
jrose7004's Avatar
jrose7004
I had no trouble bolting mine down with what was in there.
Old Jan 26, 2008 | 07:31 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I didn't have any problem using the stock hardware, with the Optima 34/78 one of the biggest batteries you can but in a C5
Old Jan 26, 2008 | 07:36 PM
Vega$Vette's Avatar
Vega$Vette
Mine came with a adapter type of piece that snaps into the bottom so the wedge hold down works.
Old Jan 26, 2008 | 07:51 PM
1KLRTOY's Avatar
1KLRTOY
If its a 35/75 it will bolt down with the factory hold down
Old Jan 26, 2008 | 08:11 PM
KHM_70's Avatar
KHM_70
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I didn't need the adapter
sorry about the crappy cell phone pic
Old Jan 27, 2008 | 10:10 AM
RedSoxFan's Avatar
RedSoxFan
I have a yellow top in my 03 and I asked for the adapter when I purchased it, go back to the shop you purchased it from and request one. I bought mine from a Batteries Plus retailer, they had plenty of adapters but I had to ask for it.
Old Jan 27, 2008 | 10:28 AM
4 KRUSIN's Avatar
4 KRUSIN
I have a yellow top in mine that appears to be about the size of OEM. However yesterday at a car show, I saw a red top that is significantly smaller. I also think I read somewhere on the forum that there is a new smaller version of the Optima. Not sure.
Old Jan 27, 2008 | 10:46 AM
My red top bolted down just fine with the stock wedge. But then again, it is a 6+ year old battery and I believe they have changed the shape a bit since then. Try contacting Optima and see if they can send you a new wedge that will work.
Old Jan 27, 2008 | 10:55 AM
Patches's Avatar
Patches
I have both versions - one in each of my C5's and both work with the stock hold-down although I have the Optima block for each of them. The first I requested from Optima and the second came with the battery when I bought it.
Old Jan 27, 2008 | 12:22 PM
DeeGee's Avatar
DeeGee
Make sure you're getting the flange on the battery tucked in under the lip on the battery tray. I thought I had that problem at first with my old Red Top. I used the Optima Tray and never got a really tight fit. Once I realized how to fit it properly I found I could use the stock hold down without any trouble.
To changed to the red optima but?????????
