PLEASE HELP - Horn Problem.
Old Jan 28, 2008 | 12:27 PM
VetteFanatic007's Avatar
VetteFanatic007
Default PLEASE HELP - Horn Problem.
Gang,
I was sitting here in my office and I saw a lot of commotion at the window. I went outside and my horn was BLARING... The key fob would not turn it off, nor open the doors. I opened the door manually with the key and started the car just fine. The problem is that the horn continued to blare even with the car running. I had to remove the fuse in order to turn off the horn. Does anyone have ANY ideas of what I can do to fix this?
UPDATE - I replaced the horn relay switch and put the fuse back in. Once I put the fuse back in, the horn BLARED again. What else can I try?
Thank You,
VF007
Old Jan 28, 2008 | 01:09 PM
silverbullit99's Avatar
silverbullit99
Sounds like the horn relay is shot.. shouldn't be much to have it replaced.
Old Jan 28, 2008 | 09:52 PM
VetteFanatic007
UPDATE- I replaced the horn relay switch and put the fuse back in. Once I put the fuse back in, the horn BLARED again. What else can I try?
Thank You,
VF007
Old Jan 28, 2008 | 10:56 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
I had this problem. I pulled the fuse and never got around to replacing the horn relay (even though I have one). I put the fuse back in a year later, and the horn works fine. I've read a number of threads that reference problems in the steering wheel that included replacing a component of the airbag assembly to fix the problem. Maybe your horn button is jammed -- try banging really hard with your fist? Do a search for horn problems and the airbag threads might pop-up.
Good luck,
Vaughn
Old Jan 29, 2008 | 10:00 AM
silverbullit99
Awhile back I had a similar problem with the horn but mine was NOT going off when I pressed it. At the dealer they opened up the steering wheel where the horn is. They had to remove the air bag . then in the center of the steering wheel there's a round disk. When you lift that disk there is a long spring, this spring makes a contact when the horn pad is pressed. My problem was that the spring was slightly bent and was not making a good contact, In your case it's probably the opposite. It stays stuck. Maybe your problem is there in the steering wheel.
Or you could have a short in the horn, or a loose connection under the hood. A good electrical mechanic should be able to resolve that problem in about 30 mins or less.
Let us know what happened !
Old Jan 30, 2008 | 02:36 PM
VetteFanatic007
Gang,
Thank You for the info. I will keep you all posted.
Old Feb 4, 2009 | 10:16 AM
The Dark Knight's Avatar
The Dark Knight
I just had this same problem. Last night it just started going off and the only thing that stopped it was pressing the horn very hard. Then I was driving this morning on the way to work and I had the radio up and noticed everyone in the cars around me were starring at me. I turned off the radio and heard my horn blarring. Again I pressed the horn very hard and it stopped, but this is rediculous.
Old Feb 4, 2009 | 11:39 AM
poolboy's Avatar
poolboy
Originally Posted by 8VETTE7
This is not an uncommon problem and one member took it upon himself to solve it on his vehicle. Fix is not for the faint of heart.
http://forums.corvetteforum.com/show....php?t=1739923
Sounds like the switch in the steering wheel
To PLEASE HELP - Horn Problem.
