serious HP question
The funny thing about the big single Supra's is how they make the hp. Look at a dynograph of a highly modded big turbo one. You'll see it hovers around 150-200hp from 0-5000rpm, then shoots straight up to a peak of incredible hp numbers at around 7k rpm, then by 8500, it's done.
The "on-off switch" syndrome commonly associated with those cars is very true, and it's largely why so few of them can run decent 1/4 mi times. It takes some incredible skill to control the car with such a narrow peaky powerband and very limited traction.
But at the same time, that instant burst of peak hp is the one reason you wouldn't want to run one from a freeway speed roll-on. That's the one environment where those cars shine.
Typical example... http://images.turbomagazine.com/feat...turbo+dyno.jpg
To me, that doesn't look like a fun car to actually drive....it looks like it was purpose built to brag about a hp #.
are the high HP vettes peaky too?
As for Vettes I can speak for my ATI DS1C 346 that has a mere 700+ rwhp and is like stock under 3k and after that hold on until redline at 6800. So I will say blower Vettes do not suffer that problem and power is linear and increases as the RPMs build toward redline
