Instrument panel electrical Issue
Old Jan 30, 2008 | 12:52 AM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default Instrument panel electrical Issue
I have an electrical issue. My button lights on the left and right hand side of my instrument cluster remain (the HUD mode buttons on the right hand side and the button panels where reset and option button are on the left hand side) on all the time even without the ignition key. They are getting the juice from somewhere. They are draining my battery down. Any ideas on where I could start troubleshooting this issue.
Old Jan 30, 2008 | 11:15 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
That's a new one and I don't have a clue. I will suggest that you PM Bill Curlee as he's the resident electrical person here.
Old Feb 4, 2008 | 02:09 PM
SilvaDragon's Avatar
SilvaDragon
I'd start with the headlight switch on the stalk. Just disconnect
it under the dash. If those dash lights go out, then the problem
is likely in the switch or its wiring. If they stay on, then it could
be a short in the dash, but that seems unlikely.
Old Feb 4, 2008 | 03:11 PM
DeeGee's Avatar
DeeGee
Check the rotary switch to the left of the steering wheel that controls the panel lights. It rotates to max and then when you go through the detent it turns the panel lights on. When you do that the lights stay on even though the 15 min timer operates.
Turn that rotary to the left and the lights should go out. That may be your problem
Old May 21, 2012 | 01:26 AM
lilyorkie's Avatar
lilyorkie
you guys dont get it the dic and hud stay on no matter what you do, turn rotary either way, make it click, whater the lights stay on 24 7 365.. help.
Old May 21, 2012 | 06:20 AM
Very sound advice - Bill has helped quite a few members with their electrical gremlins.
Old May 23, 2012 | 11:55 PM
Z-Stallion's Avatar
Z-Stallion
Has anyone come up with anything? The same thing happened to my buddy too and he's so clueless. I'm trying to help him out.
Old May 25, 2012 | 10:49 PM
lilyorkie's Avatar
lilyorkie
It seems this is happenening to more and more, I have no illumination on wiper or cruise levers and hud and dic panals stay lit all the time, and no the dimmer control is not on.
Old May 31, 2012 | 06:24 PM
lilyorkie's Avatar
lilyorkie
anyone???
Old May 31, 2012 | 07:17 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Originally Posted by lilyorkie
anyone???
Well, this might lead you in the right territory. I just had a couple electrical issues resolved by replacing the 15 year old fuse box that developed a small crack causing a dead circuit even with good fuses. I predict this will be a common issue now that these cars are getting so old. A good ASE certified mechanic should be able to diagnose this for you easily....
To Instrument panel electrical Issue
