[Z06] **clutch Options?**
Old Jan 30, 2008 | 02:12 AM
Boosted04Z06's Avatar
Boosted04Z06
Default **clutch Options?**
Hey guys, I am putting back together my supercharged ls6, and am expecting around 600bhp. What clutch have you guys had the best luck with?
Dustin
Old Jan 30, 2008 | 01:58 PM
Slow Z06's Avatar
Slow Z06
(ears)
Old Jan 30, 2008 | 02:12 PM
RonVette2's Avatar
RonVette2
Old Jan 30, 2008 | 02:56 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I am running a Ram twin disk in my car for almost 2 years now. I am extremely pleased with the clutch and will be keeping it a long time.
Old Jan 30, 2008 | 03:48 PM
97 SC Cobra's Avatar
97 SC Cobra
Good to hear. I just bought one. Do you run slicks?
Old Jan 30, 2008 | 04:28 PM
Sigforty's Avatar
Sigforty
Yep, at the track I have a CCW drag pack I use with 26x11.5x16 Et streets. Before the drag pack I used 26x11.5x17 et streets on my front Z06 rims.
Old Jan 30, 2008 | 06:42 PM
redtopz's Avatar
redtopz
I've heard very good things about the Textralia OZ00, Cartek, and Spec 3+ clutches. I have the Tex Exoskel twin disk in my 600 bhp gto, but I wouldn't want it in a vette. Its really grippy, noisy, and hard to daily drive with a very stiff pedal feel. Its great at the drag strip though
Old Jan 30, 2008 | 08:46 PM
ssmith512's Avatar
ssmith512
I had a Centerforce Dual friction clutch in my 2003 Cobra that had nitrous on top of the blower. 600+ RWTQ @ 3000rpm in a 3800lb car, w/ drag radials. Hooked just fine. Absolutely stock pedal effort. Excelent feel. I liked that clutch so much I just bought one to put in my Z. My Z presently has a Spec Aluminum flywheel and Spec Stage 3+ clutch in it, not a big fan of either. I am dumping the aluminum flywheel for a steel one. Car is not a drag car, just a weekend toy and the aluminum flywheel is a PITA for stop and go driving, and I do not like the feel of the Spec clutch or its very high catch point.
Old Jan 30, 2008 | 09:29 PM
CraZee ZO6's Avatar
CraZee ZO6
Ive had great luck with my SPEC 3+ and stock iron flywheel.
Old Jan 31, 2008 | 08:11 AM
97 SC Cobra
An adjustable master would allow you to adjust the pedal to your liking, but, if you don't like the alum. flywheel you're going to ditch it anyway.
OP- search ls1tech in the corvette section for threads on spec clutches. I wouldn't put one in my car if it was given to me.
Old Jan 31, 2008 | 08:56 AM
pit-man's Avatar
pit-man
Default McLeod Twin
Dustin
AlwaysinBoost has been using a McLeod Twin with great results..and a lot more more RWHP than you are at. Hopefully he will see this and chime in. I am installing one in the next couple of weeks.
Pit-man
Old Jan 31, 2008 | 09:14 AM
Sigforty's Avatar
Sigforty
Very true, I went from a SPEC to the Ram and could not be happier. The Spec clutch just wore out to quickly.
Old Jan 31, 2008 | 09:57 AM
pit-man's Avatar
pit-man
Sig,
we need to get a "tried and true" list going of clutchs that are actually being drag raced and about how many runs they lasted (and of course the RWHP of the abuser). Alot of replies will be from normal driving and we can't judge those with the hard use clutches. I am on clutch 4 in 24months. This is getting old quick !!
Pit
Old Jan 31, 2008 | 10:46 AM
97 SC Cobra
And I like my toes.
Old Jan 31, 2008 | 06:20 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have tried every clutch under the sun, and have stuck with the Textralia's. I would recomend the OZ700 for most drivers at that power level, or the Exo Skel if you are a serious racer. They will both hold fine, but the Exo Skel shifts slightly better on high rpm power shifts etc.
I have the twin in my road race car, which is a huge cam NA motor and dont have any trouble with street use at all. The only complaint I could say is you here the disc's rattle when the clutch is pressed with a NA motor like that, but not with a FI cam.
We have plenty of OZ700's in stock and should have a restock of Twins shortly if any one is interested
To **clutch Options?**
