Jack damage on C5
Old Feb 1, 2008 | 11:23 AM
bakerboats's Avatar
bakerboats
Default Jack damage on C5
I just bought a 2000 vert with 34000 miles. It is very clean...however I noticed that it has a small 1-1/2" hole in the floor board under the passenger side of the car like a jack was misused. Some of the balsa wood is missing also. To repair this can I place some fiberglass and resin into the hole and cover it with fiberglass or should I bond (with glass) a small piece of stainless to cover the hole to prevent water intrusion? I can also use 3M 5200 to bond this to the stainless piece if the experts feel this would be more appropriate. What would work best and any other ideas would be appreciated. This is my first post so I hope I'm doing this correctly and in the right section. Thanks for any and all help.
Old Feb 1, 2008 | 11:28 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Fibreglass should do well. Buddy of mine had the same thing and we did a ribleclass plug. (Rolled up fibreglass soaked in resin. In hole than patched. He hasn't had any trouble with the fix at all.
Old Feb 1, 2008 | 11:40 AM
bakerboats's Avatar
bakerboats
Default Thanks
Thanks so much for the fast reply. I will try that.
Old Feb 2, 2008 | 06:54 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
5200 is a great product also.......either way you go it should be fine.
Old Feb 2, 2008 | 05:13 PM
Marcs c5's Avatar
Marcs c5
5200 will work good and may be faster and just as strong.
Old Feb 2, 2008 | 05:35 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
To Jack damage on C5
