Deltran Battery Tender Plus Questions
Old Feb 2, 2008 | 03:28 PM
rdrnr's Avatar
rdrnr
Default Deltran Battery Tender Plus Questions
I was thinking of buying one and had a couple of questions. Do the alligator clips connect to the + and - battery posts and is this the preferred way and will they be secure? Is it better to connect the - alligator clip elsewhere?
With the connections made can the hood be secured properly?
Any help will be appreciated.
Old Feb 2, 2008 | 03:46 PM
WetteVette's Avatar
WetteVette
I have the Deltrans Battery Tender Plus. Great product btw.
You can either use the alligator clips to the battery, or get the auxillary power cord (my prefered method) and run it off the outlet in your center console. That way your hood stays closed.
Old Feb 2, 2008 | 03:53 PM
Timbrr's Avatar
Timbrr
Default Battery Tender
Old Feb 2, 2008 | 03:57 PM
hotwheels57's Avatar
hotwheels57
I answered on your duplicate post.
Old Feb 3, 2008 | 11:30 AM
rdrnr's Avatar
rdrnr
thanks for the help
Old Feb 3, 2008 | 11:40 AM
Big Kidd's Avatar
Big Kidd
I've been using the Battery Tender Plus for about 2 years now. They are a great product. No problems at all.
Old Feb 3, 2008 | 01:24 PM
Patches's Avatar
Patches
I have been using the BT Plus for more than 6 years without any issues. I connect mine to the battery posts and run the BT cord out the edge of the hood. I fully close the hood without pinching the cord, no problem - you just need to watch where you run it.
Old Feb 3, 2008 | 01:44 PM
rickko's Avatar
rickko
Bought my 1st BTender about 10 years ago, then used almost daily when not riding my Harley. It failed 3 years later.
It has a lifetime warranty so I sent it back to Deltran for repair/replace. They replaced it without issue. The new one has been in operation ever since (7 years).
In Jan of '05 I bought a second one for a car I didn't drive much. I modified the battery side of the pig-tail so it was permanently attached to the car's battery making the pig-tail easily accessible when needed.
Otherwise when not in use on the car it is always attached to my other m/c and continues to work daily to this day.
Highly recommend!
..rickko..
To Deltran Battery Tender Plus Questions
