oil additive
Old Feb 6, 2008 | 05:43 AM
ov666's Avatar
ov666
Default oil additive
Does anybody add slick50 to there moble one oil? I due with my pickup but i use a plan multi grade oil.
Old Feb 6, 2008 | 06:18 AM
shepsvettes's Avatar
shepsvettes
Default oil
Old Feb 6, 2008 | 08:34 AM
MiamiCowboy's Avatar
MiamiCowboy
Snake oil.
Old Feb 7, 2008 | 04:21 PM
The Wanderer's Avatar
The Wanderer
From your owners manual
Engine Oil Additives
Don’t add anything to your oil. The recommended oils
with the starburst symbol are all you will need for good
performance and engine protection.
Old Feb 7, 2008 | 05:16 PM
hotwheels57's Avatar
hotwheels57
I do not (duen't) use any additives with MOBIL 1 oil...
Old Feb 7, 2008 | 08:16 PM
u4ick's Avatar
u4ick
Slick 50 is teflon based..............ever notice what happens to a teflon coated pan after it's heated and colled a few hundered times...
The only engine additive I've ever heard of that is wirth looking into would be ER (Energy Release) it has a guarantee to replace any engine up to $100k if it causes damage to your engine......but good luck on getting that prooven.
Truthfully no need to put any kind of additive in a motor that runs with synthetic oil.
But if you're determined to do something "better" than what it came with then you could consider Amsoil which would be pretty much the same as mobil 1 but if you added their "special by-pass filter" system with it..........it claims to completely stop engine wear.......and you never change oil......every 15k or maybe it's 25k you take a sample of your oil and send it in and they will tell you when to change the by-pass filter you then top it off again (about 2 qt's)........the claim is that synthetic oil never breaks down.
Not sure how factual all that is........my father runs Amsoil in everything he has..........changes filter every 7,500 and oil and filter at 15k he's never had any issues with doing this.
I ran Amsoil in my 2 cycle jetski and it performed great.....never smoked same with my dads outboards....never had any plug fouling either.
Good as it may or may not be, I'm still using Mobil 1
Old Feb 7, 2008 | 09:02 PM
HUMVET51's Avatar
HUMVET51
According to the service manual,Mobil 1 is the recommended oil to use. The engine was also designed to use Mobil 1. Also, its not recommended to add any oil additives to Mobil 1..
Old Feb 7, 2008 | 11:47 PM
Internets_Ninja's Avatar
Internets_Ninja
Slick 50 is GARBAGE
Mobil 1, Royal Purple, Amsoil, Penzoil Plat are the only oils u should use in an LSX engine.
Old Feb 8, 2008 | 12:50 AM
u4ick's Avatar
u4ick
What else would you expect a service manual to say?
My Yamaha service manual said to use nothing but Yamalube 2 cycle oil.....so what!
I don't always do what the TV tells me to...........I'm a rebel
Old Feb 8, 2008 | 04:03 PM
LT1driver's Avatar
LT1driver
snake oil in my opinion, used it once in a truck years ago and didn't see any difference, waste of my money
Old Feb 8, 2008 | 06:24 PM
BitViper's Avatar
BitViper
I use this
Originally Posted by Info
Is a concentrated MOS2 (Molybdenum disulfide) additive, which can be added to your existing motor oil. Offering you the same load absorbing protection as the MOS2 ANTIFRICTION oil. MOS2 is a protective barrier for older engines with marginal oil pressure. Helps protect upper valve train components , where low pressure oil starvation normally occurs. Great protection for new cars also
Old Feb 8, 2008 | 06:27 PM
81c3's Avatar
81c3
I dont put any addatives in my Vettes. I DO use one in my work truck though.....Lucas. I have 155k miles on the engine & it uses no oil & really looks pretty clean even after 5500 miles of use.
Old Feb 8, 2008 | 08:53 PM
Bob CTS's Avatar
Bob CTS
Just say no to additives.
Old Feb 8, 2008 | 11:55 PM
JC in XTC5's Avatar
JC in XTC5
Old Feb 8, 2008 | 11:57 PM
moserbe's Avatar
moserbe
Bad, bad, bad!!
Old Feb 9, 2008 | 12:25 AM
Jacks02's Avatar
Jacks02
NO!
Old Feb 9, 2008 | 12:28 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
To oil additive
Old Feb 9, 2008 | 01:35 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
additives
Old Feb 9, 2008 | 02:18 AM
DeeGee's Avatar
DeeGee
Another NO
Old Feb 9, 2008 | 02:28 AM
gpracer1's Avatar
gpracer1
The Vette, no.
In my 93 Tahoe I put some slick 50 in at 36,000 miles.
I once forgot to change the oil for 25 k miles.
It now has 180,000 on it,some of the hardest trailer pulling, 4X4ing, sand duning abuse evar, and it still runs great.
I have however replaced the transmission 3 times, 2 water pumps, power steering pump, 4 radiators, rotors, drums, wheel cylinders and calipers, 3 alternators, ujoints, starter, AC comperssor, rear end gears and all bearings, and some little stuff.:o
Does it work on an old iron block? Who knows.
Lucky for me I was an ASE master tech, so I didnt have to spend anything but parts on the repairs or this truck would have cost me $100,000 by now.
