Ok, here is what I want to do.. I am going to be adding a FAQ page on our website and I want to get as many common questions answered as I can.. If everyone could post a question or two that either they have now or remember asking at one time I would love to use them for the site.. So C'mon guys and girls, lets hear them...
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
I think the most important thing you do is have the proven answer to the question of net results and deliver it. You haven't missed your mark once in all the things you guys have done for me in the over 5yrs from the smallest performance mod to the highest.
Should I consider Turbocharged or Supercharged? What are the differences in performance, initial costs, upkeep, and what additional costs of heads, valve springs etc. should I consider to enable a stock engine be able to handle the additional power. It would be great if you could include dyno pulls of a similar engine with turbo added then with charger added.
What can I buy that will give me the biggest bang for my buck?
What is the best ratio differential for the A4?
At what point should I get a hardened output shaft installed?
After upgrading the A4 gear ratio and installing a header kit what would be the next step?
At what point should I get a dyno tune?
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Explain the differences between the Dyno-Jet and Mustang Dynos, and which one do you use.
Do you perform the dyno tune and then store it on a device like a Predator? If so - can the Predator be returned for additional modifications and tuning as changes are made.
Will a basically stock LSx benefit from a performance tune with simply intake and exhaust modifications (headers)?
A thorough but simple explaination of the column lock problems, the various GM recalls, and when (and when not) the after-market electronic fixes can be used.
There are many posts and info in the header now, but it takes a detective and a lot of reading to sort through it all.
Supercharging on stock C5 4L60E auto and stock diff. At what H.P. do they start breaking or upgrades needed in either to handle significant H.P. upgrades? Just assuming you do supercharging, trans (or clutch) and diff upgrades are mandatory.
What is a torque converter? Why should a change a stock one
for a higher stall and how will my Moded vette react with the
higher stall torque converter. You could also discuss the extra
heat that can be produced.
Just a idea I already know the explanation. Good Luck
My list would be the questions that I asked you before coming over- mainly, What prep should I do before bringing my car for a tune? Answer: clean and charge air filter, replace plugs, get high performance wires, and especially in my case, do a top end treatment (eg. SeaFoam) to reduce knock.
(I'll be back to see you in a month or so when it warms up a tad.)
Actually I waas really looking for any general question that a lot of people have covered in this thread. They can be anywhere from a tuning question to what a torque converter is and anything inbetween..
What kind of gains can I expect from LT headers? Do they require a tune? What about CAI. What is the best one. What can I expect from a gear change. Does a cam change require new valve springs? and yadaydayda. Thats all I could think of right now.
