[Z06] removing sensors
Old Feb 7, 2008 | 11:37 AM
vettecrazed1's Avatar
vettecrazed1
Default removing sensors
how do you remove the sensors from an 08. Z06 wheel.
B
Old Feb 7, 2008 | 01:03 PM
BlackZ06's Avatar
BlackZ06
You're in the wrong forum ... but ....
Deflate tire
Break the bead
Remove nut from tire valve/TPMS
reach inside tire and pull out from wheel
NOTE ... I believe a C6 goes into a "reduced performance" mode if the TPMS are not working.
Old Feb 7, 2008 | 01:16 PM
TEXHAWK0's Avatar
TEXHAWK0
If this is true, then a GM engineer somewhere needs to be shot.
What if you want to go to a non-runflat tire, and just don't want the sensors? Surely you can go racing without having to reprogram the car.
Old Feb 7, 2008 | 11:30 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Be sure to notify GM's Complaint Department.
BTW, the sensors can be disabled with a Tech 2.
Old Feb 8, 2008 | 12:11 AM
Russ K's Avatar
Russ K
Why not use the tire sensors with non-run flat tires? I installed the tire sensors on my 2001 ZO6 as do a lot of ZO6 owners. If the tire pressure drops below ~25 psi, the DIC shows which tire is low & the warning chime alerts the driver. Then I can use the air compressor to air up the tire until I can patch or plug the tire.
Russ Kemp
To removing sensors
