[Z06] Partition keeps falling?
Old Feb 8, 2008 | 10:24 AM
4SFED Z's Avatar
4SFED Z
Default Partition keeps falling?
How can you keep your partition from falling forward in your Z? I have the vette tray to. I saw the DIY section and not comfortable with drilling holes in the car. Can anyone help me out on this?
Old Feb 8, 2008 | 10:38 AM
bumble-z's Avatar
bumble-z
Default partition
Hi, Go to Home Depot & get heavy duty velcros. Pull partition out & put velcros top & bottom, slide back in,Done!! Good luck, Bob.
Old Feb 8, 2008 | 08:43 PM
BaseballDude's Avatar
BaseballDude
I'll have to try that...I'm having the same problem with keeping my partition in one spot and snug up against the top/bottom.
-Deano
Old Feb 8, 2008 | 11:20 PM
overBlown's Avatar
overBlown
first things first, make sure that it is back ALL the way. in order to do that you'll have to push on it more then you might think. i went through this when i first got mine and wondered why the fit was so poor and it kept coming forward. then one day i got frustrated and really gave it a shove and what do you know, it fit like a glove!
Old Feb 9, 2008 | 01:34 AM
Novat_99's Avatar
Novat_99
I'm not sure what model you have...but, mine fits snug in place & never moves. It also had some velcro lined on the curved portion and running on the bottom corner edges (about 8" on each side)...if you look closely at the first picture, you can see what I'm talking about...you might want to try that.
Old Feb 9, 2008 | 08:49 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Funny, I had too much Velcro on mine and had to remove some to get it in place.
Old Feb 9, 2008 | 02:45 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Mine has velcro on it also and never moves. It is under the curved area over the wheel hummps and for about 8 inches on each side on the bottom. After you attach the velcro to the partition, use some blue painters tape over the velcro so you can slide the partition into place and then pull the blue tape. The partition should be held pretty good now. The velcro on mine is held in place by staples.
Old Feb 9, 2008 | 07:11 PM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
Use only Industrial strength Velcro from Home Depot.
Old Feb 9, 2008 | 11:00 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
If your using Andy's partition.....drill the 2 holes and install the snaps as per the instructions and it does not move. No one is going to see the holes or the snaps.
Old Feb 9, 2008 | 11:07 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Use Velcro, it worked for me
Old Feb 9, 2008 | 11:44 PM
bluestreak63's Avatar
bluestreak63
Did you buy it from a vendor or make it yourself?
It should fit snug...meaning you'll have to somewhat push it in to get it to seat. Otherwise, like previous responses said, get some velcro...
Old Feb 10, 2008 | 12:53 AM
bud miller's Avatar
bud miller
use the snaps....i've had mine in for 3 yrs...
un-snap and out she comes.....sounds kinda erotic...
Old Feb 10, 2008 | 02:23 PM
fej's Avatar
fej
Andy's partition fits great, snaps hold it in place and adds a little safety element from items in the trunk sliding into the cabin under "normal" driving conditions
Fej
To Partition keeps falling?
