Battery tender installation ?
Old Feb 8, 2008 | 04:34 PM
EFNFAST's Avatar
EFNFAST
Default Battery tender installation ?
So it's red alligator clip to red battery post, black alligator clip to black post (I don't have to ground it to the frame like the instructions say to??), plug it in and I'm set? Just want to make certain I'm not missing any steps, like disconnecting the battery or something.
Old Feb 8, 2008 | 04:40 PM
hotwheels57's Avatar
hotwheels57
You can use the red + and black - alligator clips or the more "permanent" ring terminals to connect to your battery. I use the latter.
Some prefer to use remote mounting of the + and - leads to reduce changing of sparks igniting out gassing from the battery. I use only OPTIMA batteries so it isn't a concern.
Read the instructions so you'll know what the different LED lights mean as the charger does its thing.
Old Feb 8, 2008 | 07:22 PM
vett79's Avatar
vett79
I just picked up a float charger also and I want to mount the wires using the ring connectors. I tried mounting them between the battery and the battery cable but the ring connector did not fit well.
It seems like the cleanest way would be to purchase the accessory type bolts for the cables and mount the ring connector to
the "accessory terminal". If so how do the bolts come out of the cables?
Is this the way most of you are mounting?
Thanks in advance!
Old Feb 8, 2008 | 07:30 PM
csexton's Avatar
csexton
I have mine hooked up the same way and no problems for 3 years and running
Chuck
Old Feb 8, 2008 | 07:54 PM
DPG's Avatar
DPG
St. Jude Donor '06
Thanks in advance!
you can cut the old ring terminals and crimp on ones that will fit your terminal needs. will take you 2 min to cut and crimp on new ones
Old Feb 8, 2008 | 08:19 PM
vett79's Avatar
vett79
I swapped out the ring connectors to 3/8" and they fit over the bolt OK but it didn't look like the cable was fitting against the battery like it should with the ring in between. Maybe I'm just paranoid. I'll try it again.
Old Feb 8, 2008 | 09:49 PM
The way you are connecting yours is the way I do mine. Never a problem.
Old Feb 8, 2008 | 10:35 PM
oaks99's Avatar
oaks99
oak
Old Feb 8, 2008 | 10:41 PM
vette2k1's Avatar
vette2k1
Is there a reason that you don't want to follow the instructions?
Old Feb 8, 2008 | 10:43 PM
NYCHASM's Avatar
NYCHASM
From: Probably talking that police officer out of giving you a summons! ========== The Beautiful Lower Hudson Valley, NY
St. Jude Donor '08-'09
Thanks in advance!
You really didn't get a "float" charger, did you?
Charlie
Old Feb 8, 2008 | 10:47 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
me to. Read the instructions also so you know what the little LED lights mean. I love the tender, just hook it up and forget about it until spring
Old Feb 8, 2008 | 11:00 PM
jlbruggeman's Avatar
jlbruggeman
If you got the real Deltran Battery Tender, if you hook it up wrong, nothing bad will happen, the light just won't go wrong. Unfortunately, the weather being the way it is, I have one on each Corvette, plus the Harley....can't wait for spring!
Old Feb 8, 2008 | 11:06 PM
moserbe's Avatar
moserbe
Old Feb 9, 2008 | 02:55 AM
DeeGee's Avatar
DeeGee
Me too
Old Feb 9, 2008 | 10:02 AM
peebee_c5's Avatar
peebee_c5
Originally Posted by hotwheels57
....out gassing from the battery. I use only OPTIMA batteries so it isn't a concern....
The Optima is a VRLA - AGM battery. VRLA = valve regulated lead acid. The valve is there for outgassing, to let the hydrogen out.
Hydrogen is as much a concern with the Optima as it is with any other modern maintenance-free battery. Hydrogen will generally only be generated during charging -- but your battery is charging whenever the engine is running or whenever you have it hooked to your battery tender....
Old Feb 9, 2008 | 12:16 PM
white top's Avatar
white top
I use the battery tender with the cigarette liter plug. Fast easy no need to open the hood.
Jerry
To Battery tender installation ?
