i'm scareed to go fast on the stock runflats because they are so hard it feels like i'm sliding across the street at all times. what tires do you all run an you stock wheels? (i have thinspokes) anyone have the nitto "INVZO'S"?
PS---i want the most grip w/o having to get some radials.... just some damn good street tires.
Thet still give the protection of runflats but have a softer sidewall (rated for 50 miles flat not 200). The noise and handling is way better than the stock
If you go non run flat the choice is a lot wider.
i'll be goin non run-flat in my quest for traction.
I like my BFG G-Forces, I dumped the run flats 2 WEEKS after buying the car. My car would skip literally 1-2' in a corner when cold. I have the original G-forces and the grip is incredible, and they were reasonable, tire Rack, all four, $730.!!! I have floored my car in 2nd gear in the rain, no issue, cold weather, no issue. Great tire for the money!!
[QUOTE=The California Kid;1564042895]I love my runflats. I'll never drive without them. Whenever I drive fast, I feel like I'm glued to the road. Maybe you have some other issues?
Run Flats are right depending on your decision of comfort level and risk zone.
My decision was to go with Vredstein Sessenta's I went with 275/40/ZR17 98Y on the front and 295/35ZR18 103Y on the rear of my 01 vert.
No fitment issues. No rubbing or scuffing, just a nice change from the noisey, hard riding, slick sliding, EMT's that now adorn a corner in my garage......
Run flats superiority on long trips doesn't make sense either... good luck trying to find a run crap tire in the middle of no where when you get a flat! Yea guess what it is not like you can drive on the "flat" run flat for more than 50 miles anyways...
And then get ready to get shafted for $600 by your friendly billy bob store after it takes them 2 weeks to order a tire for you since they don't carry run flats.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
tia
If your Goodyear EMT's are original - they have gotten hard as the rubber has aged. But quite frankly - the Corvette engineers and the Goodyear engineers worked in tandem for several years to develop a tire that would meet all of the performance criteria for the then new C5 - including wet and dry traction, braking, handling, as well as ride characteristics, and wear characteristics. The final design that was OEM on the C5 met and exceeded all of those requirements. Most importantly - it was and still is the only tire designed to run without air for up to 200 miles at speeds up to 55mph. None of the aftermarket extended mobility tires will conform to the original specifications, and many of them cannot be repaired if punctured.
Here is an interesting article that discusses this tire.
Having said all of this - any tire that is going on eight years old will dry out. And when the rubber dries out, it becomes less pliable. This loss of pliability will contribute to the feeling that the tire is harder, feels less sticky and they begin to make more noise.
I'm not defending the OEM EMT's - but I think it is important to understand the reason why the tire demonstrates the characteristics about which we all complain.
