HID Headlight Conversion Kit
Old Feb 15, 2008 | 10:22 PM
Art Smart's Avatar
Art Smart
Default HID Headlight Conversion Kit
I just bought a HID headlight converstion kit. It includes new ballasts and bulbs.
When I originally installed them only one light worked, the passenger side. The vendor was great and sent overnight replacement ballasts. With the new ballasts still only one light worked. the passenger side again. I switched the ballast and lights, they both work, but only on the passenger side.
When I re-installed the factory bulbs they work fine, on both sides. I don't think it's the ballasts or bulbs because they both work on the passenge side, just not on the driver's side. Is it my car? if so, why would the original bulbs work just fine on both sides?
I'm stumped, any ideas? I'm hoping my fellow Forum members are smarter than I am.
Old Feb 15, 2008 | 10:32 PM
jdmvette's Avatar
jdmvette
Night Owl for life
try reversing the 2 wires in the one side that didn't work.
Old Feb 15, 2008 | 10:34 PM
knight1975's Avatar
knight1975
mine do it all the time when .I just turn the high beams on, and switch back and they work fine.
Old Feb 15, 2008 | 10:36 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I am wondering if you changed everything to the other side including the harness. If not, you could have a pin pushed back in the clip or something. You could have opened the female pin up by accident. What you need is a test light or even better a good Volt / Ohm meter. You need to measure the voltage across the wires going to the ballast as close to the ballast as you can on the problem side. I expect you'll find that you're missing voltage somewhere. If you are, chase the wires back and find where your open circuit is. Keep your probe on the positive wire and use the chassis ground. If your voltage appears, then you have an open ground circuit. Make sure you probe both wires because if you have an open ground circuit to your ballast and you're using chassis or any alternate ground, you will not discover your problem. Most problems such as intermittent opening and closing and bulb start failures will be cured if you use a relay to power them. I would recommend using a fuse link at the alternator to get the highest voltage to the ballasts.
Old Feb 16, 2008 | 12:39 AM
Junkman2008's Avatar
Junkman2008
I'd go with Jason's suggestion first...from experience.
Old Feb 16, 2008 | 12:56 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Old Feb 16, 2008 | 02:34 AM
99torchredlb's Avatar
99torchredlb
Originally Posted by C5Vette168
always something simple
Old Feb 16, 2008 | 05:03 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
Well as mentioned try changing the wires. We have some HID's on our Z06 and didn't have any issues, but I have a couple friends with Mustangs that only 1 light will come on when the car is off, to get both to come on they need to start the car, you might try that.
99TorchRed..How do you like your HID's?
Old Feb 16, 2008 | 06:32 AM
Phanni's Avatar
Phanni
Some manufactureres recommend upping the fuses to 20 amps.
Old Feb 16, 2008 | 11:26 AM
Art Smart's Avatar
Art Smart
Thanks for all the replies, I'll start with the easiest ones. In a few days I'll let you know if one of them worked.
Old Feb 16, 2008 | 12:45 PM
jrprich's Avatar
jrprich
I have been telling everyone that posts about HIDs to use a dedicated battery based relay wiring harness......resolved all my issues. You can buy such a harness on the bay for $20-30 shipped
Every quality aftermarket lighting system comes with such a wiring harness.
http://forums.corvetteforum.com/show....php?t=1942184
Old Feb 16, 2008 | 03:35 PM
Quik Z06's Avatar
0Quik Z06
Former Vendor
Good to know if you have problems Ive installed 4 total so far and havent had any of the issues you had but i'll kep this in mind.
Old Feb 16, 2008 | 03:50 PM
Robs98Z28's Avatar
Robs98Z28
Had the exact same problem when I did mine. Make sure you have both of them plugged into the wiring harness the same way. I only had one working and it turned out the one that didn't work was backwards. Also, you probably need to upgrade the headlight fuse and the one to the right of it to 20A from 10A (in the underhood fuse panel.)
Old Feb 16, 2008 | 06:01 PM
rws.1's Avatar
rws.1
Many of the kits have been wired with ground and +'ve reversed...
Just turn the connector around to test it.... It wn't lock, but if it works you can take the time to disassemble the connector and reassemble correctly.
Old Feb 17, 2008 | 09:24 PM
Art Smart's Avatar
Art Smart
Default They work !!!
You guys are great. I mistakenly did what rsw.1 did, I put the connectors together so they would click together, bad idea, the wires ended up being crossed. Dumb mistake.
Thanks again
Art
Old Feb 17, 2008 | 10:34 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Thanks again
Art
Not dumb, honest mistake. I've done three HID kits now, low&fogs on the vette, and lows on the lincoln. Easy to plug in backwards.
Glad you got it worked out.
Old Feb 18, 2008 | 12:01 AM
jrprich's Avatar
jrprich
I've done a few of these kits from different vendors and only one set of the ballasts had the male socket on the ballast marked + and - which has led to many folks having failures during install.
To HID Headlight Conversion Kit
