[Z06] What the heck is causing this?
Old Feb 19, 2008 | 01:17 PM
sperkins's Avatar
sperkins
Default What the heck is causing this?
At 70mph and above, the windshield sounds like it's rattling on the passengers side.
I can't figure it out because I'm too busy driving to hop over to the other seat to listen. All the weatherstripping is tight and the glass is not loose. Could it be the friggin wiper arm? Have any of you ever had this problem?
'03 Z.
Old Feb 19, 2008 | 01:20 PM
stock z06's Avatar
stock z06
check your rear view mirror..
mine was loose and was making the same noise...
good luck,
eddie 2002 Z06
Old Feb 19, 2008 | 01:25 PM
civlant's Avatar
civlant
Not above 70 but whenever I hit bumps I hear a rattle on the passenger's side. I found tht it was the passenger's seatbelt (the metal loop) tapping against the bottom of the door.
Old Feb 19, 2008 | 02:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXACTLY!!!!!!!!!!!! Same problem! Pull it across and buckel it into the seat latch and I bet it goes away!
BC
Old Feb 20, 2008 | 04:00 AM
coolbubba's Avatar
coolbubba
Check the exterior molding at base of windshield-mine rattles at speed ever so slightly-yet to fix. Has your windshield been replaced?
Old Feb 20, 2008 | 04:41 PM
tvlance's Avatar
tvlance
HA wow! I love this forum. I've had the exact same sound for a long time now, but I figured it was so petty and never bothered to post about it. It's a rattle sound coming from the lower passenger side edge near the windshield. It definitely sounds like something fluttering around in the wind, so I think it's on the outside. I was going to stuff little bits of foam into the vertical windshield fairing and see if that helps. The mirror is tight, and I know it's not my seatbelt. The windshield is original on my car I'm pretty sure. When I research more, I'll post on what I find out.
Old Feb 20, 2008 | 06:02 PM
sperkins's Avatar
sperkins
Please do. I'm going to give mine another good once-over tonight. Wish me luck.
Old Feb 21, 2008 | 04:20 PM
c5_4_me's Avatar
c5_4_me
you know, i thnk i may be one with the exact same rattle.
Old Feb 21, 2008 | 07:47 PM
ctusser's Avatar
ctusser
Oh, for friggin's sake! That's what that is, I've been ignoring it for the last year b/c I couldn't find anything loose
Thanks for the share
Old Feb 21, 2008 | 11:34 PM
jay'szo6's Avatar
jay'szo6
Ya it's worse when you have polished stainless door sill covers like I have. Nothing a lil more throttle and a lil more volume on the radio can't fix.
Old Feb 21, 2008 | 11:44 PM
02 batmobile's Avatar
02 batmobile
Same here, darn passenger side seat belt banging away!
Old Feb 22, 2008 | 06:21 PM
Cirrus8's Avatar
Cirrus8
I had a rattle that sounded like it was coming from the outside near the top of the winshield and it defied finding. Then one day when the conditions were making it rattle, I just happend to change the position of the sunshade and the rattle STOPPED. It was the sunshade mirror cover hitting the top frame -- but only under cirtain road and speed conditions.
Old Feb 22, 2008 | 06:30 PM
Atok's Avatar
Atok
Old Feb 22, 2008 | 07:06 PM
civlant's Avatar
civlant
No problem, glad I could help
Old Feb 22, 2008 | 07:19 PM
tvlance's Avatar
tvlance
I wish my rattle was as simple as some of you have found in your situations. But with sperkins and I, it's a bit more complicated. So as I said before, I'll do some more testing, but I have to wait until the weather here improves. It's such an annoying sound, like a little something flapping around in the wind on the outside of the windshield. I need to get more in the habit of making short video/audio clips of anything I describe (benefits of working in television) and post them on Photobucket. I'll see if I can't do that for this issue soon.
Old Feb 22, 2008 | 07:25 PM
Crash94536's Avatar
Crash94536
I also have problems with some annoying noises coming from the passenger side. The part that sucks is that it gets worse the faster I drive. I do my best to shut them out.
Not sure what it is but it's only there when the wife is in the car.
Old Feb 25, 2008 | 08:36 AM
Bugaboo's Avatar
Bugaboo
Very Good Crash!!
To What the heck is causing this?
