Duct tape removal?
Old Feb 22, 2008 | 11:32 PM
vettegator005's Avatar
vettegator005
Default Duct tape removal?
someone decided to duct tape my car all over and it came off just fine except the white residue stayed on the car and is very difficult to remove anyone have any ideas how to clean it off?
Old Feb 22, 2008 | 11:35 PM
BanditDude's Avatar
BanditDude
WD40 is safe. You'll just have to re-apply the wax, which you'd have to do anyway. Good luck.
Old Feb 22, 2008 | 11:36 PM
DeeGee's Avatar
DeeGee
Sorry to hear about the problem. What kind of person does that to a nice car.
I've used goo gone in the past which has worked fine. Other members have suggested WD40. Either way I'd do a test run on an area thats not so obvious first.
Old Feb 22, 2008 | 11:37 PM
bmw2nv2000's Avatar
bmw2nv2000
OMFG is "someone" dead, cause if it was my car they would be. Dang I dont know I am pretty dang good with a buffer and Im not sure compound will take of that you may have to use reducer to rub all the residue off then you have to buff the entire car. Good luck
Old Feb 22, 2008 | 11:51 PM
moserbe's Avatar
moserbe
Go to NAPA and buy some tar remover. It will cut thru the white crap.
Old Feb 22, 2008 | 11:56 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
that sux! At least it was only duct tape. Better than getting keyed. Good tips above! Good luck!
Old Feb 23, 2008 | 12:13 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Well, after you permanently disable the SOB's, you use the bloody side of their living flesh to wipe down the car......no, that won't get the tape residue off, so wipe something else up with them and use one of the suggestions above.
That is some totally serious BS....you need new friends.
Old Feb 23, 2008 | 12:16 AM
blkchipC5's Avatar
blkchipC5
plus it's real easy to use...just soak good and wipe off with a towel.
Old Feb 23, 2008 | 12:17 AM
TraceZ's Avatar
TraceZ
I've used WD40 many times to get crap off cars.
Old Feb 23, 2008 | 12:28 AM
gunnerja's Avatar
gunnerja
St. Jude 15 Year Donor
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Goo remover works good also. No matter what you use clean it well afterwards and give it a good heavy waxing.
Old Feb 23, 2008 | 01:15 AM
Bill Dearborn's Avatar
Bill Dearborn
Soap and water work just fine. If it takes too much elbow grease then wash it and use a cleaner wax. I put duct tape on my car all the time when I go to the track. It isn't that hard to get the stuff off as long as you don't leave it there for a couple of years.
Bill
Old Feb 23, 2008 | 01:17 AM
PierEagle's Avatar
PierEagle
WD40 or PennzGuard will clean the goo and is a good tar remover also and will not (never has on any of my cars) hurt the paint.
Old Feb 23, 2008 | 02:07 AM
mark man's Avatar
mark man
Be carefull with the clear coat. That just sad that peaple are so f_ _ ked up
Old Feb 23, 2008 | 02:11 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Word!!!
Old Feb 23, 2008 | 02:48 AM
striper's Avatar
striper
I've used mineral spirits with good results and it's safe.
Old Feb 23, 2008 | 03:20 AM
dieseldave56's Avatar
dieseldave56
Default adhiesive residue
3M adhiesive remover
Old Feb 23, 2008 | 03:46 AM
WildTurkey's Avatar
WildTurkey
Thats just WRONG....good luck with the clean up
To Duct tape removal?
Old Feb 23, 2008 | 10:45 AM
tricep's Avatar
tricep
St. Jude Donor '09
This stuff works great.
Doesn't remove the GF or spouse though...
Sorry.
Old Feb 23, 2008 | 11:10 AM
damilleniumboy's Avatar
damilleniumboy
HCL joke, tar remover does wonders, and wd-40 does too; unless you want to try HCL.
Old Feb 23, 2008 | 01:40 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
