How offen do you add engine oil?
Old Feb 24, 2008 | 06:55 PM
BUGZ's Avatar
BUGZ
Default How offen do you add engine oil?
I've had my mostly stock 99 Hard Top with now 28K miles since last October (~5 months). I've driven her ~2500 miles. I've added about a quart during this period. Is this normal?
Driving habits = not very aggressively, however I do put my foot in it once in awhile.
Thanks in advance for your advise.
BUGZ
Old Feb 24, 2008 | 06:56 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Knock on wood but mine only needs oil when I change it... Of course most folks know I don't drive mine so I'm not sure I count....
Old Feb 24, 2008 | 07:03 PM
R Devil's Avatar
R Devil
Never had to add between changes. 10k
Old Feb 24, 2008 | 07:04 PM
JTS97Z28's Avatar
JTS97Z28
Yeah I agree why would you be adding oil any other time other than during an oil change unless there is something wrong? So to answer your question I add no oil between oil changes. I dont add any to my 03 Z06 and didnt have to for my 99 hardtop either.
Hope this helps,
J.T.
Old Feb 24, 2008 | 07:06 PM
Bob CTS's Avatar
Bob CTS
No addition of oil is needed on mine.
iflex2fitness's Avatar
iflex2fitness
only at time of oil change.
Old Feb 24, 2008 | 07:07 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
My 99 did not use oil at all between oil changes, now that I have FI on I use oil depending on how much boost I decide to run
Old Feb 24, 2008 | 07:11 PM
black98c5's Avatar
black98c5
Never needed to add oil and I run my car pretty hard at times.
Old Feb 24, 2008 | 07:28 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have a 2002 coupe and I never have to add oil till I change it, Around every 4000 miles.
Old Feb 24, 2008 | 07:34 PM
Oldvetter's Avatar
Oldvetter
I have a 1998 Coupe with 110,000 miles and I never use any oil between 6,500 mile oil changes.
Old Feb 24, 2008 | 07:39 PM
jrose7004's Avatar
jrose7004
I only need to ad oil when I change it.
Old Feb 24, 2008 | 07:42 PM
vetter79's Avatar
vetter79
Noe added between changes here either! 70K + miles
Old Feb 24, 2008 | 08:04 PM
BUGZ's Avatar
BUGZ
Thanks for the replies. Sounds like I may have an oil consumption problem. Anybody have an in site on what the contributing factors could be for having to add oil between changes?? The guy I bought it from said he put in oil that was supposedly better than Mobile 1, not the Purple stuff, something else...don't remember the name. I don't have any leaking or blue exhaust.
Old Feb 24, 2008 | 08:17 PM
Overboosted's Avatar
Overboosted
AMSOIL?
Old Feb 24, 2008 | 08:36 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Oil loss can come from a variety of sources. Most common in LSx motors is oil loss by the rings into the cylinders and out the exhaust. This is most common at high rpm, low load conditions and was very common in the early LS6 motors that had numerous TSBs out on oil consumption. Depending on how you drive, this may or may not be noted by some. Other possible causes include loss into the PCV system (take off the intake at the throttle body and see if you have oil in front of or behind the throttle plate). To correct this, many guys that track the car disconnect the PCV system from the intake (where it dischages to) and connect it to a catch can. Then there is the obvious oil leaks. Not really sure how common any of these were on the LS1 in the 99 FRCs, but suspect that there are similarities given how similar the LS1 is to the LS6.
You might try a google search for TSBs (technical service bulletins) on your car and look for titles regarding oil consumption.
Another common cause often overlooked, and probably the primary difference between the losses from one oil brand to another is the oil's volatility. Many low cost oils essentially evaporate at the oil temps seen in the Corvette. For an example, look at the NOACK Volatility results on this AMSOIL commissioned test:
Comparative Motor Oil Test Nov 05
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 24, 2008 | 08:44 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
60K mileage and only when I change the oil.
Old Feb 24, 2008 | 08:45 PM
marcvobx's Avatar
marcvobx
Me Too! I only change every 3000 miles or so!
To How offen do you add engine oil?
Old Feb 24, 2008 | 08:48 PM
steve8's Avatar
steve8
Same here.
Old Feb 24, 2008 | 08:49 PM
vettelover84's Avatar
vettelover84
Mine goes about 1500-2000 miles and I need a qt of oil!! Thinking about doing a re-ring, not sure when though... I wonder what it will cost to do a re-ring.?$?$?$?
Old Feb 24, 2008 | 09:43 PM
AlisonC5's Avatar
AlisonC5
Alot more $$$ than the oil you are adding!!! 2001's are notorious for oil consumption.
To the OP: 58K, no oil consumption here, and I don't baby it but I don't beat it to death either.
