The official stupid C5 question thread
Old Feb 25, 2008 | 09:51 PM
drivestwin's Avatar
drivestwin
Default The official stupid C5 question thread
I just purchased my C5 last fall and have a few questions I have been afraid to ask. So lets consider this the official stupid question thread…….don’t be afraid to ask that question that you have always felt too embarrassed to ask. Just add your question with a number that can be referenced in the answer.
1. Did all convertibles come with the standard seats or was sport seats an option?
2. Do all aftermarket cat back systems come in 4 pieces, or are some of them in 2 pieces like the stock exhaust?
3. What is the top speed of the non Z06 C5 and can anybody confirm this?
4. How often does the synthetic oil need changed in the C5? Also, anything special about the C5 I need to know about when changing the oil?
5. What is the recommended trans service interval?
Old Feb 25, 2008 | 09:56 PM
happa's Avatar
happa
3. Fuel cut off is 172, I believe
cant help you on the others
Old Feb 25, 2008 | 09:59 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
3. I have had my coupe north of 190 and 4. every 5k or once a year is what I did when I was stock
Old Feb 25, 2008 | 10:03 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Showoff
Old Feb 25, 2008 | 10:22 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Wuss.........
Old Feb 25, 2008 | 10:48 PM
Whiteonrice's Avatar
Whiteonrice
Mine didn't cutoff at 172.
Rick
Old Feb 25, 2008 | 11:24 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Rick
Nor did mine
In keeping with the thread:
Will it do the speedometer?
p.s. Answer::::::::::: net yet
Old Feb 25, 2008 | 11:35 PM
34RedRage's Avatar
34RedRage
#2- ghl bullets are a 2 piece per side system...
Old Feb 25, 2008 | 11:42 PM
superjet701k's Avatar
superjet701k
1. i have rocking seats
3. i passed my headlights so i let off
4. mine like a clean drain pan so i can pour it into my waste oil heater
Old Feb 26, 2008 | 12:00 AM
jbauch357's Avatar
jbauch357
1. Sport seats were an option, far as I know Z06 models didn't come with them cause of the electric motors that weighed so much.
3. If memory serves it's 176, Z06 models actually had a lower top speed cause of lower gearing - and the cars are gear limited in 5th gear cause 6th doesn't have enough power to pull up past 5th gear redline
4. watch the oil life meter in the trip section of the dash options, change it when you get into single digits.
5. if it's a manual every 50k should be sufficient, if you drive hard or track do it once a year or so.
may not be perfect answers, but they are pretty damn close...
Old Feb 26, 2008 | 12:05 AM
Trigger Creep's Avatar
Trigger Creep
Not sure about all years of C5, but Sport Seats were a reg production option in Verts.
I have seen a couple, but they're easier to install in pieces. Just adjust them and tack weld them into place.
The magazines say 167 for the 6sp coupe (in 5th). Thier word is good enough for me. I'm not sure about the Z.
The DIC will give you a percentage of oil life remaining. Some owners will still go 3k, some 5K, some change once a year (low mi drivers) some wait for the DIC - up to about 15k for some. If you're in a hot, dry, dusty climate, I'd recommend a lower mi change routine. I go 5K between changes. Its an easy number to remember.
There is a Delco Gold synthetic filter (UPF44) for our C5's It traps a smaller particle than cheaper paper filters. Contact Bob at Fitchner Chevy - a supporting dealer here on the forum. Great folks. West Coast has them too.
http://www.westcoastcorvette.com/p-9...il-filter.aspx
To reset the oil life, pump the throttle 3 times with the engine off and key on. You can also do this through the menu on the DIC.
I'm not sure one this one. Check this thread >
http://forums.corvetteforum.com/showthread.php?t=984927
Nice slingshot rail! I hope you wear a cup
Old Feb 26, 2008 | 12:10 AM
1. Sport seats were an option.
2. All the aftermarket cat back systems I've seen have been in four pieces.
3. Top speed for the coupe was 175 with the vert a little slower.
4. The oil should be changed according to your oil life monitor on the DIC - or at least yearly if you don't drive it enough to have the computer tell you it is time to change the oil.
Old Feb 26, 2008 | 01:43 AM
DeeGee's Avatar
DeeGee
1. Did all convertibles come with the standard seats or was sport seats an option?No. Mine has sports seats
2. Do all aftermarket cat back systems come in 4 pieces, or are some of them in 2 pieces like the stock exhaust? Got me on that one
3. What is the top speed of the non Z06 C5 and can anybody confirm this? I'd seen 178 but were in the right ballpark. Best I've seen so far is 120 (down a runway)
4. How often does the synthetic oil need changed in the C5? Also, anything special about the C5 I need to know about when changing the oil? Use the DIC Oil Life Monitor - its a good calculation but change it at least every year.
5. What is the recommended trans service interval? According to the service schedule change the fluid in an A4 at 50k miles. The book also says MN6 fluid doesn't need changing
Old Feb 26, 2008 | 01:55 AM
IAIA's Avatar
IAIA
4. Here's a tip on the oil...if you do it yourself: After all has drained, tip up the rear end an extra inch or three and watch another 1/4 quart come out. Good to the last drop. Sweet.
Old Feb 26, 2008 | 02:13 AM
thetaxman's Avatar
thetaxman
I don't think there is a fuel cutoff
Old Feb 26, 2008 | 08:07 AM
Enthusiasts's Avatar
Enthusiasts
Default stupid question to add
6. What type of Transfluid is the longest lasting best you could recommend?
7. Best type of oil to recommend? Live in MD so east coast cool climate, very humid.
8. I know 6 and 7 are probably opinions but I am sure a couple will come up more then once.
Old Feb 26, 2008 | 09:59 AM
jbauch357's Avatar
jbauch357
remember to be specific as to the car you're working on, we know it's a C5 but there are lots of different models/options out there that will all have impact on answers. case in point are you asking about a manual trans or auto?
6 - Regardless of if it's a manual or auto, AmsOil ATF.
7 - Mobil-1 5-30 factory fill
To The official stupid C5 question thread
Old Feb 26, 2008 | 12:00 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^Don't have the specific answers to your questions but I can lead you to the right place.
First off, your owners manual should have information about changing fluids.
Second, in terms of options available check out this site.
http://www.corvetteactioncenter.com/specs/
If I recall correctly, the top speed of the coupe is about 175 mph. The coupe has the highest top speed of all the C5s because it is the most aerodynamic of the 3 styles.
Old Feb 26, 2008 | 12:17 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
the coupe is faster (top end) than the Z06 but the Z06 is quicker
Old Feb 26, 2008 | 12:30 PM
TheLegacy81's Avatar
TheLegacy81
I have a stupid question to ask
When a fault code is sent out on the DIC, does it beep? or notify you?
