Either I'm crazy or....
Old Feb 27, 2008 | 12:49 PM
jbauch357's Avatar
jbauch357
Originally Posted by SebringSixSpeed
On a more serious note, I used to work as an alignment tech for about 5 years. So I feel qualified to say that you have effectively decreased your castor angle by raising the rear of the car. You should feel that the steering is less effort and more responsive to your input. Straight line accelleration should not be affected in this situation, but the handling should be much improved.
raising will also change camber towards the positive side - you should take it to a good shop and make sure everything is correctly adjusted.
and yes, I also did 4-corner caster/camber/toe alignments on many makes and models for about 5 years...
Old Feb 27, 2008 | 12:55 PM
byte_me's Avatar
byte_me
Originally Posted by jbauch357
so remember the difference between a waxer and a driver when it comes to getting advice on this forum...
Can I get an AMEN!
I am going to be putting in Z06 springs\Sways with metal end links and Bilstein Sport shocks shortly- when all is done, I will have it aligned etc...
Old Feb 27, 2008 | 04:42 PM
joeracer49's Avatar
joeracer49
Originally Posted by 65GGvert
It makes sense, it's just physics. If the back is lower than the front, you're going up hill all the time. Now that the back is higher, it will be faster and you'll get better gas mileage because you're running down hill.
