Either I'm crazy or....
Old Feb 26, 2008 | 09:49 PM
byte_me's Avatar
byte_me
Default Either I'm crazy or....
the car feels faster after puttting it back to the stock ride height in the rear!!
I bought the car and the previous owner lowered just the rear on stock bolts- I was hitting bottom over bumps so I raised it back to normal (or close to it) the cars attitude has changed dramatically! I mean going from a hauling bricks to hauling ***! It feels more snappy for some reason??
anyone else notice this going back to stock height?
Old Feb 26, 2008 | 09:57 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Maybe you just feel more comfortable giving it throttle knowing you won't drag azz????
Old Feb 26, 2008 | 10:58 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I think you've finally lost it man
Old Feb 26, 2008 | 11:08 PM
BATM4N's Avatar
BATM4N
You sure you haven't added a hood seal
Old Feb 26, 2008 | 11:51 PM
jrose7004's Avatar
jrose7004
You're right, you're nuts!
Old Feb 27, 2008 | 12:06 AM
tlc0706's Avatar
tlc0706
Perhaps the higher altitude has affected your reasoning
Old Feb 27, 2008 | 12:07 AM
lil vette's Avatar
lil vette
instal RED mats, will go even faster. (mine did)
Old Feb 27, 2008 | 12:10 AM
SebringSixSpeed's Avatar
SebringSixSpeed
Cool, I'm going outside right now to raise mine back up, what do you think I can expect? 15 rwhp? 25?
Old Feb 27, 2008 | 01:17 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Old Feb 27, 2008 | 07:14 AM
byte_me's Avatar
byte_me
I know, I know....sounds like I lost my mind... like I said, just the rear was lowered- the nuts on the rear bolts were completely threaded down to the very last thread...in this configuration it felt as though the weight shift when you got on it was off, meaning the balance was not there...just like I had a lot of weight in the rear of the car all the time...once it went back up- it feels like it transfers the weight better under acceleration... the rear of the car actually looked like it may have been lower then the front slightly...
It's not really a horsepower thing like the hood seal...its more like the car has the weight more equally distributed to all 4 corners now and hence the ride and effort of faster take off's has gotten better...
Old Feb 27, 2008 | 07:20 AM
RSchleder's Avatar
RSchleder
Man, can you imagine how fast it would be if you put a "lift kit" in it!
Old Feb 27, 2008 | 07:29 AM
byte_me's Avatar
byte_me
now that would be sum'thin...
Old Feb 27, 2008 | 08:12 AM
65GGvert's Avatar
65GGvert
It makes sense, it's just physics. If the back is lower than the front, you're going up hill all the time. Now that the back is higher, it will be faster and you'll get better gas mileage because you're running down hill.
Old Feb 27, 2008 | 08:21 AM
BT-01-vette's Avatar
BT-01-vette
Maybe it's a aerodynamics thing.
ZO6 Lee's Avatar
ZO6 Lee
Higher is faster! Golly, height= speed. Something to remember.
Old Feb 27, 2008 | 09:36 AM
byte_me's Avatar
byte_me
I think it has to do with proper weight distribution...many people when going to the track like to put their cars on scales and weigh each corner and make adjustments to the suspension to equal it out...I believe that the engineers had this in mind when they put the suspension together for the C5 and when it is modified irregularly- the results make the car feel lax or heavy...
I know I am not that crazy...the car responded to the height increase in the rear- perhaps it is not really faster but more balanced and allowed the car to perform up to its expectations rather than below them.
Old Feb 27, 2008 | 11:15 AM
Robls6's Avatar
Robls6
Uh.... OK Beavis!
To Either I'm crazy or....
Old Feb 27, 2008 | 11:23 AM
jbauch357's Avatar
jbauch357
bingo! when people lower their cars they need to go down the same amount on the front and on the back. when unevenly raising/lowering on one end or the other happens not only do you change the aerodynamics of the car you are effecting the corner weighting and overall suspension travel potential from one end to the other.
but then again that doesn't matter to a lot of people because they care more about the asthetics of the car than the actual handling potential. sounds like you drive the car, so remember the difference between a waxer and a driver when it comes to getting advice on this forum...
Old Feb 27, 2008 | 11:35 AM
bucwheat's Avatar
bucwheat
Sure It Did.:d
Old Feb 27, 2008 | 12:35 PM
SebringSixSpeed
On a more serious note, I used to work as an alignment tech for about 5 years. So I feel qualified to say that you have effectively decreased your castor angle by raising the rear of the car. You should feel that the steering is less effort and more responsive to your input. Straight line accelleration should not be affected in this situation, but the handling should be much improved.
