C6 wheels on a C5
Old Feb 29, 2008 | 01:17 AM
97C5driver's Avatar
97C5driver
i bought a set of c6 painted wheels that i will be painting black and was wondering which spacers i would need.
looks like 5/16.
Paul, was there enough thread left on the lugs to feel comfortable that the wheels are bolted on securley?
Old Feb 29, 2008 | 01:19 AM
97C5driver's Avatar
97C5driver
Originally Posted by bucknutt76
your a good guy man, thanks for the advice. do they even make 3/4 spacers?
Paul is the man. He hooked me up with a rear spring bolt overnight fedex when mine snapped and chevy couldnt get one for a few days. I was able to drive the vette over the weekend and make it to a corvette event.
Old Feb 29, 2008 | 01:40 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
looks like 5/16.
I got 5.5 turns w/ 5/16 spacers. 1/4" will give you more turns and the tires will only be in a 1/16" more. Your call, I "think" the way I have it it will work. Maybe a little lock tight to.
I was glad to do it. Thanks again for the parts I got from you.
Paul G.
Old Mar 2, 2008 | 11:00 PM
unionlandlord
C5 General
Originally Posted by unionlandlord
My 5/16" spacers did the trick. I can tell right away, it looks right.
Paul G.
I took the Vette out today. Turns out the 5/16" spacers are to big. The lugs were not tight when I got home (2 miles and upto 8 lbs of boost) to see how thay were doing.
Im taking them off and am going w/ longer lug nuts. So IMO I would not use them w/ stock lugs.
Paul G.
Old Mar 3, 2008 | 02:23 AM
NIKDSC5's Avatar
NIKDSC5
okay I need wheels to fit over c6z calipers and I do not want to use spacers. I would also like the c6z look to please tell me one of you know of such a thing!
Old Mar 22, 2008 | 10:22 PM
caliguy2004's Avatar
caliguy2004
6th Gear
Sorry to dig this thread up...
Without thinking i ordered a set of oem 18/19 c6 rims. Now i have no idea whats the best way to fix this.
1/4 spacer seems like it works without problems. is this correct? Where can i buy spacers for my car?
Old Mar 23, 2008 | 01:27 AM
Marc77's Avatar
Marc77
I just put a set on my C5. The easiest thing would be to get the 1/4" spacers for the rear. Get billet aluminum spacers. I ordered mine from Jegs.com and they arrived in two days. $60 for a pair.
http://www.jegs.com/i/Baer+Brake/136...759919%7C11611
I'm happy with the results and have no issues. Most importantly, the car looks sweet
Old Mar 23, 2008 | 01:36 AM
jorgito's Avatar
jorgito
[IMG][/IMG][IMG][IMG][/IMG][/IMG]
Old Mar 23, 2008 | 12:30 PM
NJAnthony's Avatar
NJAnthony
HOUSEOFWHEELS has replicas made for C5s... he is a great forum vendor. I went with the C6 Z06 Wheels... no spacers or anything needed.
Old Mar 23, 2008 | 03:50 PM
LV,99LS1VERT's Avatar
LV,99LS1VERT
Unless your going to put C6 Z06 brakes,go with 18/10.5 17/9.5 like these.
Old Mar 23, 2008 | 04:02 PM
Bill Vett's Avatar
Bill Vett
I went with 18x9.5 (265-35-18)and 19x11 (305-30-19) C6-Z06 wheels from Bob's House of Wheels, they have the proper offset for the C-5. No spacers and no rub and lowered on stock bolts. price shipped for all 4 wheels was under $1K.
Old Mar 23, 2008 | 04:10 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Just get stock C5 sizes!
Old Mar 23, 2008 | 04:23 PM
  #33
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
They are all good looking wheels.
Old Mar 26, 2008 | 10:43 PM
  #34
bradleyls103's Avatar
bradleyls103
Ok this is what I want mine to look like, what size rims, tires, and spacers are you using. Also what did you do to lower it?
Old Mar 27, 2008 | 09:59 PM
  #35
caliguy2004
6th Gear
Just Got Mine Installed Today!!!
I used 1/4 Spacers on the rear, and that fixed the problem. If you want to lower the car i would suggest you to get 1/2 and longer studs.
Here are B4 and After Pics...
Before:
After:
Old Mar 27, 2008 | 10:02 PM
  #36
bradleyls103
Before:
After:
Are they chrome or polished? OEM or aftermarket? Runflats? Where did you get them. They look great!!!!!!!!
Old Mar 27, 2008 | 10:06 PM
  #37
caliguy2004
6th Gear
They are the OEM C6 Polished Wheels and Eagle F1 Runflat Tires that come stock on a c6. I bought them off ebay, and the guy said he took them off within 1000miles when he bought the car.
Thanks So MUCH!!!
