[Z06] Ls6 Hot Cam?
Old Mar 5, 2008 | 08:16 PM
VETTOZO6's Avatar
VETTOZO6
3rd Gear
Default Ls6 Hot Cam?
IM LOOKING FOR A HEADS/CAM PKGE.DAILY DRIVER.WOULD THE LS6 HOT CAM BE GOOD? OTHER?
THANKS...
Old Mar 5, 2008 | 08:36 PM
GONZZO's Avatar
GONZZO
I read a post recently, a member was asking about the GM hot cam. Most of the replies stated there were better cams for less money. If you do a search for hot cam you should be able to find the post.
Old Mar 6, 2008 | 08:59 AM
g1k05's Avatar
g1k05
i would stay away from the hotcam. not because its bad, but because like mentioned above there are better cams for less money. hotcam is a fairly small cam too. it lopes hard, but its not big.
Old Mar 6, 2008 | 10:40 AM
DPG's Avatar
DPG
St. Jude Donor '06
with the posts above.
You can go with a much larger cam for cheaper and still have daily drivability. Heck, the cam I'm running now isn't bad for a daily driver. 232/234 112 lsa and its not even tuned yet.
Old Mar 6, 2008 | 12:47 PM
earthman01's Avatar
earthman01
Try the G5X3 cam from LG and AFR 205's shaved to 10.5/1. You'll like it.
Old Mar 6, 2008 | 01:16 PM
Labold's Avatar
Labold
What kind of power will the G5X3 and a set of AFR 205's give a bone stock '01?
Old Mar 6, 2008 | 01:41 PM
g1k05's Avatar
g1k05
i personally wouldnt daily drive a g5x3 cam. but thats just me. futral cams have nice DD characteristics. i have one on a 110lsa... its not bad at all. once i get a ti exhaust back on, it will be real nice to daily... even though i wont.
Old Mar 6, 2008 | 03:19 PM
AU N EGL's Avatar
AU N EGL
plus LG LTs, a good CAI, under drive pulley, and a great tune, mid 400 min to upper 400s is very possible.
To Ls6 Hot Cam?
