new tires
Old Mar 6, 2008 | 01:14 PM
JOHN MOORE's Avatar
JOHN MOORE
Default new tires
Just put a set of Michelin Zero Pressure tires on my '00 coupe. Have never run anything except the Goodyear run flats until now. With the stock tires, I ran a cold tire pressure of 30 pounds all around. Should I do the same with the Michelins?
Old Mar 6, 2008 | 01:45 PM
Bill Vett's Avatar
Bill Vett
YES...Look at the drivers door it tells you the cold psi for the car. Doesn't matter what tire, it's a starting point. Check tire wear often and adjust the psi . Center wear lower 2 psi, outside wear increase 2 psi and keep an eye to abnormal wear. Also if you got new tires a 4 wheel alignment would be a good idea. Bill
Old Mar 6, 2008 | 02:36 PM
JOHN MOORE's Avatar
JOHN MOORE
I did get the 4 wheel alignment...car sure rides better...thanks.
Old Mar 6, 2008 | 02:51 PM
Bill Vett's Avatar
Bill Vett
Now you can turn down the radio and talk in the car.... I switched about 4 years ago and couldn't believe how much more fun the car was to drive.
Old Mar 6, 2008 | 05:50 PM
They can be set at the same psi as the Goodyears.
Old Mar 6, 2008 | 07:06 PM
RPHCRMZ51's Avatar
RPHCRMZ51
I have had 3 sets of rears on my '01 coupe ( z51 & 3:15). I learned my lesson after 2 sets. First set 30lbs, goodbye centers on rear real quick. This new set I have kept it at 28lb and no signs of wear so far. I wish I had kept exact milage but at 30lb the centers went down within a year ( 12 - 15k / yr ).
Old Mar 6, 2008 | 07:31 PM
jrose7004's Avatar
jrose7004
30 psi.
To new tires
