Squeak from Steering Wheel?
Old Mar 7, 2008 | 11:26 AM
crazed_z06's Avatar
crazed_z06
Default Squeak from Steering Wheel?
Whenever Im turning at low speed, I get this annoying squeak sound from the streering wheel. Any idea what it might be?
Old Mar 7, 2008 | 11:40 AM
Z06ster's Avatar
Z06ster
Ya know, I too have noticed a squeak from the steering wheel. Up to now, I have ignored it, dismissing it as a GM quality issue. I'm curious to see what others have to say about it...
Old Mar 7, 2008 | 11:43 AM
OIF2XVET's Avatar
OIF2XVET
mine started doing it recently also. I know there is a post around here that talks about the way to fix it. I know it has to do with lubricating some gears in the stearing colom but not sure how to execute this as the pics on the tread I saw were very bad.
Old Mar 7, 2008 | 12:31 PM
LTVetteVert00's Avatar
LTVetteVert00
Mine does it too...Y2K Vert. Best solution is to ignore it or put the top down so you can't hear it. Poor GM engineering. My 2004 Silverado just develpoed a similar squeak. Again, poor engineering.
LT
Old Mar 7, 2008 | 03:43 PM
SinghZvette's Avatar
SinghZvette
I guess it plagues all automobile types and models. My 01 Jeep Grand Cherokee Laredo started squeaking too after the harsh winter we had here in the midwest this year.
Old Mar 7, 2008 | 03:54 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
mine does the same thing - sounds like a goose
Old Mar 7, 2008 | 03:55 PM
DeeGee's Avatar
DeeGee
This link might solve your problem:
https://www.corvetteforum.com/techti...D=35&TopicID=1
And here's another pic
https://www.corvetteforum.com/techti...s/Steerin2.jpg
Old Jun 16, 2008 | 09:32 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I agree that it needs lubricated, but is there a procedure on how much to disassemble to access whatever needs lubricated??? My 99 vert is squeaking more and more!
Old Jun 16, 2008 | 09:41 PM
jbridgett's Avatar
jbridgett
2001 Vert. The only problem I can't seem to track down. Drives me nuts. Sounds like it's coming from the upper portion of the steering column. I'm hoping it doesn't require a complete dissasembly of the column. The pictures I've seen are vague or bad. I would like to fix this. It's starting to sound like an ex-girlfriend.
Old Jun 16, 2008 | 09:45 PM
clif's Avatar
clif
I did buy the lithium spray today, hoping to find out where to spray it.
Old Jun 17, 2008 | 12:51 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Mine had the same problem a couple months ago. I read the threads about lubricating the bearing, but luckily the squeak went away.
Old Jun 17, 2008 | 09:45 AM
jedblanks's Avatar
jedblanks
Honestly I think I know where the location in that picture is, but those are TERRIBLE pictures. I guess since no one else has a picture (I've asked in the past), I'll post one when I spray mine.
Old Jun 17, 2008 | 10:03 AM
jovette's Avatar
jovette
about the quality of the pictures!
Please do take and post better pictures for all of us. I have the same problem, and I have the can of lithium grease, but I'm just like a lot of other forum members and am simply waiting to hear more specifically where it should be applied.
Old Jun 17, 2008 | 10:40 AM
Enemy's Avatar
Enemy
Turn up the radio, take the top/targa off, its just a small squeaking sound, mine does it also, once in a while
Old Jun 17, 2008 | 10:46 AM
cjcvette's Avatar
cjcvette
Looking forward to the pics!
Old Jun 17, 2008 | 10:51 AM
clif's Avatar
clif
I plan on digging into my steering column this weekend. If there are no pics on line before that, I will document what I do.
Old Jun 17, 2008 | 08:43 PM
jedblanks's Avatar
jedblanks
I sprayed what looked like the picture on the inside, no difference, noise seems to be behind a rubber boot at the inside firewall.
I went to the outside firewall side under the hood and sprayed and it made a little difference.
You can't get in there with a can of spray, so use a light and route a piece of vacuum line to where you want to direct the spray, then stick the wd-40 nozzle stick into the vac line. -- I'd recommend wd-40 because it will penetrate.
It still makes a small noise at onset of steering wheel movement, but then quiets while turning.
It's directly below/behind the brake booster, but I ran the vac line along the steering shaft up to where I wanted it to go.
I can't get a shot of either wiith a camera, which is why I guess there are no pics. You'd have to stand on your head and get lucky.
To Squeak from Steering Wheel?
