St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
LG Big 3 Video
Hi guys,
I know you all have been waiting for this for a while now. But here it is, the video for the LG Big 3 Video for C5's! Compete with a close up look, dyno, and idle!!
I was expecting more volume. Good looking system however, i like the numbers they are doing so far. Will you be planning on testing them against pacecars?
Volume shmolume .. I'm no engineer but I think it's all about diameter and backpressure .. 3" baby. if you want the system to be loud as hell inside and out, remove the mufflers from the equation. I think LG would be glad to run a straight pipe there .. ??
This is the first system I've seriously considered replacing my stock TIs with.
It does under throttle, but the biggest complaint we have heard was interior volume, so we tried to keep the interior as comfortable as possible.
That should be an option muffler delete with test pipe substitution!!!!!!!!!!!
Looks Nice! I only wish it was louder. Do you have any plans to make a system for those of us more hard core types????? With smaller and lighter Borla Stinger type mufflers?????
Do you have a video of this setup with no cats? I have your LG Pros ready to be installed, and am thinking about ordering the catback as well but don't want anything that will wake the dead. If you can make a video that would be great.
I believe they are 12lbs heavier than the Titanium system....but almost anything is going to be heavier than that (Ti system).
would like to know exactly how much more....and also would like to know the weight difference from manifolds/cats/factory xpipe to LG Pros Offroad 3" xPipe ....maybe the difference would even out the weight...I just dont want my Z weighing anything more than stock....what kind of power increase would one see going from Stock Ti to the Big 3 on a stock engine just headers no cats and intake with a tune? thanks
From: Wylie TX --> Less is More, except under the hood !
I don't know any weight numbers, but the LG Pro Long tube sustem reduces quite a bit of weight when replacing the stock system. More than 12 lbs for sure. The stock manifolds are Cast Iron and HEAVY ! I know because I was there when Sean at LG's installed mine, and I packed up my stock system and took it home. I could not believe how much a weight reduction the LG's system was compared to stock.
