Traction woes...
Old Mar 14, 2008 | 10:02 AM
blevyouknow21's Avatar
blevyouknow21
Default Traction woes...
Getting yanked off the line by a fox body makes me hurt inside. I was feathering like crazy and still couldn't get the GYs to hook. Thankfully as I grabbed third I blew by him but the damage was done.
I'm planning on getting new wheels and tires and am stuck as to whether to go for wider tires for more money or slightly thinner tires for less.
Choices: (Rear)
295/30/19 Vredestein Ultrac Sessanta / Cheapest
305/30/19 Nitto Invo / More Expensive
315/30/19 Not sure yet / Most expensive
When all said and done the car will have no more then 400-425 RWHP. Is it worth the extra money for the extra ~.5" or ~1" of traction or will I be fine with the 295s?
Minor suspension work will also be done after I get my wheels and tires.
Old Mar 14, 2008 | 12:17 PM
blevyouknow21
Any input?!
Old Mar 14, 2008 | 02:10 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
your not really going to gain ANY traction off the line unless you are running something like a drag radial.
your not going to notice any difference going to a wider tire either. you need a softer compound tire. look at the tread rating on the tires, the higher the rating, the harder the tire, worse the traction. with a low tread rating, its going to be a softer tire with more grip.
Old Mar 14, 2008 | 02:13 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I agree, You will need to get a set of drag radials, That will help a lot.
Old Mar 14, 2008 | 02:30 PM
black98c5's Avatar
black98c5
Ditch the 19's if your going to the track or if you want traction in general. Get some 18's and go with BFG's (295/35/18 or 315/30/18 depending on rim width) or even the new MT's if you can find them. Hope you have at least a built diff if you plan on dead-hooking though. Good luck!
Old Mar 14, 2008 | 02:40 PM
blevyouknow21
Perfect explanation! Thanks.
I'm keeping my stock wagons and will buy accordingly to what I get into.
I don't want to come off as some idiot that only cares about straight racing. I love the vette for it's all around ability and am ready to upgrade my rubber. Thanks for the input!
To Traction woes...
