Got the Koni FSD's on yesterday. Food for thought though - OEM shocks are HP Gas pressurized. Before removal, compress them by jacking up the A-arm and then tie the top and bottom together using a few HD cable ties to keep them compressed. It'll make removal a he!! of a lot easier! (I didn't do it with the 1st front one and it ended up being a bitch to remove. Even had to drop the tie rod so I could pry up on the shock to compress- Rear's are easier to work on ). Even though you can compress the Koni's by hand I found that's it's still easier to use the compress and tie method to make installation easier.
Hope this helps out a little!
I use a length of heavy wire that is fashioned to allow me to hook it onto the lower end of the shock, and then compress the shock and hook the top end - thus holding the shock compressed.
This makes it much easier to r&r shocks.
best regards -
mqqn
Wire probably would have been easier - didn't think about that one!
