Need help on drive line
Old Mar 16, 2008 | 01:11 PM
Banshee6's Avatar
Banshee6
Default Need help on drive line
I have a 2000 vette and got a click noise when shift from drive to reverse. sounds like u joint to me but cant find any online. do they have a different set up,
Old Mar 16, 2008 | 01:26 PM
randy814u's Avatar
randy814u
They have a torque tube. It bolts up to the bellhousing, and then to the transmission in the rear.
http://forums.corvetteforum.com/show....php?t=1589496
It could be coming from your Half shafts. The shafts going from the rear end to the wheel. You also might want to check your wheel bearings.
Good luck, Randy
Old Mar 16, 2008 | 01:34 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
do you mean you hear it sitting at idle in neutral? or is at while sitting in reverse?
Old Mar 16, 2008 | 01:39 PM
Banshee6's Avatar
Banshee6
only going from drive to reverse or reverse to drive
Old Mar 16, 2008 | 01:42 PM
Banshee6's Avatar
Banshee6
Good luck, Randy
thanks
Old Mar 16, 2008 | 02:14 PM
LoneStarFRC's Avatar
LoneStarFRC
Sounds like the splines inside the rear wheel bearings where the bearing assembly contacts the outer ends of the axle assembly.
Remove wheel, remove axle nut, squirt some PB Blaster or Kroil inside all around the axle splines. The penetrant needs to get between the bearing hub assembly's backside and the end of the axle.
Re-install and torque the axle nut, etc.
HTH
Old Mar 16, 2008 | 09:02 PM
Banshee6's Avatar
Banshee6
Thanks on the replys
To Need help on drive line
